Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-28-2007, 07:28 PM
chickyricky chickyricky is offline
clutch pedal sticks depressed??
2002 Camaro 6 cylinder, manual trans.
2 years ago the clutch was replaced and it has worked fine since. I don't think it went out again but the clutch pedal stays depressed. I changed out the master cylinder and it still is staying depressed.The spring seems to be ok. It went out suddenly and didn't smell as a burning clutch smells. i was told to change out the master cylinder and was also told that I didn't get all the air out of the line. But it has the same problem. the clutch pedal will not come up. i was told that if you do not get all the air out the pedal will not come back up. Is this correct??? I don't think the master cylinder was the problem. Could it be the slave cylinder??? I do not see any fluid leakage around the trans.please help.
Old 11-28-2007, 09:17 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: clutch pedal sticks depressed??
Moved to Problem Diagnosis
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 11-29-2007, 10:25 AM
will69camaro will69camaro is offline
Send a message via AIM to will69camaro
That is very correct, with air in the system the pedal will stay on the floor. There should be a bleeder fitting on the slave somewhere (if it's like the t56) and you can bleed the system just like brakes. You need to get the air out for the pedal/clutch to operate properly.
William
Old 11-30-2007, 07:29 AM
Thanks for the info. I pumped the clutch pedal about a hundred times and it works like a charm!!!!
The master cylinder was the problem and air in the line will cause the pedal to stay on the floor.
Old 12-06-2007, 06:23 PM
streetsurfinseth streetsurfinseth is offline
yeah mine is sticking to the floor too but only when i romp down on it hard.... think that its my slave cylinder so ill just get it replaced when i put a clutch in it (00 T/A WS6)
00 T/A WS6
