Old 07-16-2011, 02:53 PM
masapell's Avatar
masapell masapell is offline
Replacing rear driver's side speaker
I have a 2000 3 door extended cab that I want to replace the rear speakers. I was wondering about the procedure to remove the rear driver's side speaker. It looks like the panel is behind the rear seatbelt mechanism. What is the easiest way to get to that speaker? Any info is greatly appreciated.
2014 Ram 1500 Crew Cab
Old 07-20-2011, 05:04 PM
masapell's Avatar
Re: Replacing rear driver's side speaker
Anyone, anyone....Bueller, Bueller?????
Old 07-20-2011, 09:09 PM
j cAT j cAT is offline
in this 2000 model year GM made many door styles,, look the door panel over and seek out those screws.. then when removing on my 4 dr ext cab it was very difficult to unfasten the plastic from the metal frame up on top..[clips] your 3 door I am not sure..
Old 07-21-2011, 12:13 PM
masapell's Avatar
Yeah, the door looks like it might take a little work, but is doable. The driver's side looks to be more of a pain, since there is no door there. Looking at it, it appears that the seatbelt hardware is in the way of the panel coming off without removing the anchor bolts. I guess I will see if I can pull the panel clips out and manuever it enough to the side to get access to it. I have found info on removing the door panel, but not the driver's side wall panel. Thanks for the info J!!
Sincerely,
Matt
Replacing rear left side vent glass craye Rodeo | Passport | MU 2 10-27-2007 05:32 PM
91 LeBaron Rear driver's side (automatic) window slipping/not working lynniell Lebaron 1 10-25-2005 04:05 AM
replacing the driver's side front turn signal bulb herbsing Odyssey 1 03-27-2005 11:10 PM
Rear Driver's Side Light inop jakmehard Caravan | Voyager 0 05-09-2004 02:26 PM
