Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 07-15-2011, 09:30 AM
jlrbruc23 jlrbruc23 is offline
Exclamation Accords cuts off while driving.... PLEASE HELP!!!
Hello,
My 1998 honda accord shuts off randomly while driving. I usually just throw it in neutral and restart it and keep moving.
I think its an electrical issue because everything shuts off, the engine doesnt break down. Also sometimes itll cut off and come right back on within the same second. I think something may be loose or something. Someone even gave me a ideal that something may be loose where you put the key in but i havent looked into it yet.
The car was in a head on collision and the issue started about a month after that. The collision wasnt that bad it only damaged as far back as the radiator. 3 people looked at it and even had it hooked up to a computer and it showed nothing.
Please help!!!!!! THANKS
Old 07-15-2011, 10:36 AM
danielsatur danielsatur is offline
Re: Accords cuts off while driving.... PLEASE HELP!!!
1) How old is the battery?
2) Have a load test on the battery + alternator @ the local auto parts store for free.
3) Replace fuel filter + have a fuel pressure test done.
4) Roll the fuse pump relay with another relay of same type.
Old 07-15-2011, 12:17 PM
somick's Avatar
somick somick is offline
There is a ground wire somewhere under battery. It could get damaged during collision. Check it out.
Another known issue is a bad electrical portion of the ignition switch. As far as I remember somebody replaced it and had no problems ever since.
Search this site for procedures.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 07-16-2011, 02:40 PM
BullShifter's Avatar
Sounds like a bad ignition switch to me. When the engine is running try jiggling the key around to see of the engine dies. If it does then you know it's the electrical portion of the ignition switch. Very common problem with those cars.
S10 2.2L Cuts off while driving, then won't start NovaRod S-10 93 05-03-2015 09:13 PM
'95 cutlass cuts off while driving D_hammer Cutlass Series 10 11-10-2005 09:47 PM
SCARY....97 Honda Accord LX that cuts off while driving blknight1963 General Discussion 5 05-27-2005 12:53 PM
96 caravan cuts off while driving titanfan694 Caravan | Voyager 12 12-17-2004 02:07 PM
99 burban cut off while driving cdilallo C/K 0 09-12-2004 08:04 PM
