Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-15-2004, 08:58 PM
D_hammer D_hammer is offline
'95 cutlass cuts off while driving
I have a 1995 cutlass suprem that will just cut off while driving. It will start back up with no problem I can drive it for a while and it will cut back off. I've had a new fuel line filter put on. I had the dealership to look at the car they place a new brain/computer in the car and told me that they could not locate the problem.
If anyone has encountered this problem any info that you share will be greatly appreciated.
Old 03-22-2004, 04:13 PM
#1mammy #1mammy is offline
I also have a '95 Cutlass Ciera which I bought in Aug. '02. It was fine til Apr. '03. Then it developed a BAD case of the stalls. It has now stalled way over 200 times.
I can just FEEL it go, so I pull over as quickly as I can and shut it off before losing the steering and brakes. All I have to do is cuss (or count) to about 30, then turn it back on and drive off. It might be 3 or 4 weeks before it stalls again, or it might do it 6 or 7 times during the same driving trip.
The first place I took mine said he had seen a similar problem, but the lady wanted her computer replaced...it didn't fix the problem. The second place I took mine had not seen the problem before. Neither place could find anything when they used the diagnostics machine.
My new manager just told me last week that the car he bought for his daughter is doing the same thing.
I'm hoping someone will answer you with a solution...SOON.
Old 04-08-2004, 10:01 PM
0annie 0annie is offline
Re: '95 cutlass cuts off while driving
I have the same thing going on and I can't seem to trouble shoot it. Help, will any body.
Old 04-09-2004, 10:56 AM
tiflhenr tiflhenr is offline
I have a 92 that cuts off too
My 92 cutlass did the same thing, but wouldn' t start immediately after quitting. It would about thirty minutes later. I replaced the fuel filter thinking that would solve the problem. Later, it did the same thing, so I replaced the fule pump. Now it won't start at all. The spark plugs are getting no spark at all. When it rains it pours.
Old 04-09-2004, 04:43 PM
ee_lime ee_lime is offline
My 95 olds cutlass sup would cut out while i was driving, it ended up being a coroded wire near the spark plug box
Old 04-10-2004, 02:43 PM
Old English Old English is offline
It may be worth checking the ignition coil module and the contacts for the wire. Try to borrow one from a pal and change it for a day or so
Old 04-22-2004, 08:25 PM
ve3sjk ve3sjk is offline
could be your answer
Hi All,
I have an 89 cutlass that had a simalar problems that cost me much more than it should have to repair.
Here were what mine was doing
cutoff while driving (engine quits)
poor idle
no start
All tracing of the trouble first pointed towards the fuel pump which was repaced. This did not fix the problem. We then traced the fuel pump relay wiring back to main computer where there was not 12v pulse to turn on fuel pump.
What the problem turned out to be was the OIL PRESSURE SENDING UNIT, the computer will shut off the fuel pump if it thinks that the car has no oil pressure from a defective sending unit. This will not give you any engine codes.
Try changing the sending unit its to the right of the oil filter under the engine, you will need a special socket for the unit that you should be able to rent.
Hope this helps
Steve
Old 11-02-2005, 10:12 AM
JJR2 JJR2 is offline
My '94 Ciera "S" had similar problems, due to two different failures:
- The transmission torque converter lock-out became corroded, dirty, or weak and sometimes failed to release the converter when the car slowed from highway speeds. When it needed to downshift, it just stalled instead. I disconnected the lockout solenoid, which may reduce cross-country mileage, but corrects the problem. I may get industrious enough to replace it eventually.
- The idle air control valve was dirty. The engine would just abruptly stall, usually at idle. These were expensive, so I cleaned up the old one. This corrected the problem.
Old 11-07-2005, 10:02 PM
kennedy330 kennedy330 is offline
Unhappy
ive got kinda the same problem, my 86 cutlass will run for about an hour and stall, it wont start for about 30 min and then starts right up. i think it might be the fuel filter but i cant find it anywhere. any help will be apreciated.
Old 11-08-2005, 12:21 PM
Scootzilla Scootzilla is offline
Send a message via AIM to Scootzilla Send a message via Yahoo to Scootzilla
I had a problem like this b4 when i first got my cutty it is a 96 supreme.I replaced the fuel pump and the filter did not help ok maybe alittle.It turned out to be a bad cable at the jumper post on the engine.Replaced all my cabled pos & neg and the jumper post cable and has not stalled yet in about 6 months.
Scoot
Old 11-10-2005, 09:47 PM
cutlassthatstalls cutlassthatstalls is offline
ive also heard about these cars being built with faulty fuel injectors, if nothing else is wrong replace your injectors with ones for a 1996 and this will fix it
S10 2.2L Cuts off while driving, then won't start NovaRod S-10 93 05-03-2015 09:13 PM
2001 windstar cut off while driving kmichael30 Windstar 1 01-19-2005 08:24 PM
87 Town Car Sudden Cut off while Driving Blazer Man Town Car 1 12-25-2004 02:57 AM
96 caravan cuts off while driving titanfan694 Caravan | Voyager 12 12-17-2004 02:07 PM
99 burban cut off while driving cdilallo C/K 0 09-12-2004 08:04 PM
