Old 07-14-2011, 09:24 PM
Cruize Cruize is offline
Rear Axle Questions
95 Blazer, GT4 rear (3.73 gears), G80 positraction
I changed both rear axle seals and now need to tighten the pinion lock bolt. How do I clean the oil off the bolt and out of the hole that it goes in so I can apply Loctite? The bolt is too long to be removed without removing the diff. I was thinking of shooting brake cleaner through the hole. Is there a better way?
How do I measure the ring gear so I know which one I have? I could try wrapping a string around the gear, measure the circumference and then calculate the diameter. Just curious so I know which torque spec to use.
Thanks in advance.
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Oil capacity of GTS rear axle 2006GTS GTRA / GTWS / GTS 2 10-01-2010 07:46 PM
Rear axle question. diggin M Bodies 4 06-18-2008 02:23 PM
97 2.5L rear axle question tomvid Wrangler 0 04-08-2008 09:18 AM
Blue Bowtie, rear axle question. silicon212 Caprice 2 11-20-2006 08:20 AM
1999 can I swap a 2wd rear axle in the place of a 4wd rear axle? azwelding Silverado 2 04-25-2006 02:16 PM
