Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-08-2008, 09:18 AM
tomvid tomvid is offline
97 2.5L rear axle question
I need to replace the differential pinion seal.
Does anybody know what real axle is stock on a 97 2.5 Wrangler?
Is it Spicer 44 or Spicer 35?
Thanks!
-Tom
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
