Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 07-14-2011, 10:09 AM
cadillaction cadillaction is offline
91 Lebaron Codes 26 and 41, Engine miss
I've got a 91 LeBaron convert, 3.0 MPi that has a miss. Pulled the upper intake to gain access to fuel injectors and wiring. Check all the wiring and everything looked good. Installed a new Power module(SMEC?----I'm a GM guy) and the car started and the miss was gone.... For a few minutes. It returned along with the code 41. Pulled intake again and removed 4 wire plug and wired them direct. Some of the wires looked like they might be suspect. Put her back on, cleared codes, and same thing. It says to check the wiring going to the logic module. What and were is that. Also, I hope I didn't wreck the new power module.
There is a ground wire behind the power module that I want to sand and reinstall for good measure. I also replaced the battery cable ends that had seen days, no change.
Any help would be greatly appreciated.
Old 07-14-2011, 12:32 PM
jdl jdl is offline
Re: 91 Lebaron Codes 26 and 41, Engine miss
Do a cylinder balance test, engine running. Kill cylinders one at a time while you note the rpms. If you kill a cylinder that has no effect on rpms, that cylinder is dead. Then you check fuel--spark--compression.
Also, check the charging system or have it checked.
Old 07-14-2011, 02:01 PM
I originally did check for dead holes. #5 was the one. Had spark and compression....swapped injectors and no change. After I installed the new power module the miss was gone for a few minutes. I'll check the charging system for exact voltage. Are they that touchy????
Old 07-14-2011, 02:08 PM
jdl jdl is offline
As far as the charging system, I just went by one of your trouble codes.
You may have to check amp draw for all injectors. If something caused the old pcm to fail, you need to fix that before replacing the pcm. The problem might cause the new pcm to fail,also.
Old 07-22-2011, 12:49 PM
Jamesjjr9110 Jamesjjr9110 is offline
When you swapped injectors did the miss follow with the injector? I had same problem. dead miss with same two codes and it was bad fuel injector... went to wrecking yard got 6 injectors off a 98 voyager and put all of them on with new o-ring kit and miss gone, no CEL.
Also pull upper plenom back off and ohm out all 6 injectors. they should read cold/outside temp which is about 100 where i am somewhere around 20.0 ohms on the 200 scale. if they ohm out really high or infinite they are bad. I would suggest replacing all 6 injectors. I got my six, fuel rail, and wiring harness for around 80 bucks. I just cleaned them up with tooth brush and b-12 carb cleaner and stuck them in.
P.S. if you do have bad injectors when you replace them, you can use carb spray as a lube on the o-rings when pressing them into the fuel rail and the block. it will keep them from tearing and also when it drys it helps the o-rings to "stick" to the block and injector.
Cars I've owned oldest to newest:
89 Plymouth Voyager 3.8 v6 Stock 210k?
91 Buick Lesabre 3.8 V6 Stock 147k
91 Ford escort 1.9 I4 Stock 140k
94 Chrysler Lebaron 3.0 V6 Stock 155k
98 Dodge Caravan 3.8 v6 Stock 180k
00 Ford Crown Vic 4.6 v8 Stock 90k
Notice they are ALL American?
Old 07-24-2011, 05:22 AM
I'll have to check the miss again. Thanks!
Old 07-24-2011, 02:17 PM
No problem. Let us know how it turns out. And what you figure out.
Old 02-05-2012, 05:52 AM
cargeek88 cargeek88 is offline
this problem seems to be really tough man!!!
Old 02-05-2012, 05:03 PM
jamesslcx jamesslcx is offline
Thumbs up Re: 91 Lebaron Codes 26 and 41, Engine miss
Yes it does, I learn something new every day.
Engine Miss? FordBoss88 Taurus | Taurus Wagon 1 08-23-2010 10:03 PM
rebuilt engine misses after 375 miles? rfb427 F-Body Problem Diagnosis 2 02-25-2009 08:25 AM
Need help with error code and service engine soon moviego Alero 2 03-04-2008 06:15 PM
error codes and check engine light bikeleaver Tacoma 4 05-20-2005 09:38 PM
Clearing a code and check engine light tony2 Grand Cherokee | Grand Cherokee SRT8 1 08-03-2004 07:26 AM
