Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 07-13-2011, 10:37 PM
21sprint 21sprint is offline
1991 190e oil drinker
This car still runs good but is using about 4 qts of oil a week when putting less than 200 miles on it, it's a 2.6L and the oil looks clean. The radiator is where most of the oil is going as the fill jug is full of oil, what could be causing this? We was told a new engine would fix it but it sounds more like a blown gasket or seal.
Old 07-13-2011, 11:39 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: !991 190e oil drinker
Oh dear, that is not good at all.
Oil and water in an engine should never mix.
It means something has failed, and continuing to drive it could lead to the whole engine failing altogether.
If you lucky it is just a blown Head Gasket.
If your unlucky, water has found its way into the oil and there is bearing damage.
There could be other problems, warped head, cracked block, etc.
The only way to find out is to start pulling the engine down and inspecting things.
That can get expensive, and a swap for a used engine maybe the best fix.
1989 Mercedes 190E OVP Relay yanceycat E-Class 0 11-30-2009 08:17 PM
190e oil pan replacement GaryMM General Discussion 0 12-31-2007 11:51 AM
1991 190E, Heater and Cant turn car off ezjc1 E-Class 2 01-27-2006 07:18 AM
1991 190e niteshadw General Discussion 1 08-16-2004 01:14 PM
1999-SL-The Oil drinker ! Anup SC/SL/SW 7 03-09-2004 11:48 AM
