Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-12-2011, 06:27 PM
havie73 havie73 is offline
03 envoy acceleration
Hello im new hrer and im having a little issue with my truck i dont know if is a big problem or what but when i step on the gas pedal the truck doesn pick up as it should all you hear is the trottle make noise but slow moving like something is clogged somewere is it the vortex os something else? Please help...
Old 07-12-2011, 06:52 PM
maxwedge maxwedge is offline
A990 racer
Re: 03 envoy acceleration
Welcome to AF, not a very good description of your problem, if it sounds like a helicopter and is down on power it may be the electric fan clutch on the water pump. have a shop listen to it.
Old 07-12-2011, 07:00 PM
Thanks for the quick response again what is doing is that it wont pick up fast enough when you take off from a red light it takes time to reach speed,at cruising speeds it runs fine till you try to pass .
Old 07-12-2011, 07:01 PM
I was thinking clogged catalitic converter?
Old 07-13-2011, 04:22 PM
danielsatur danielsatur is offline
Air - Suspect bad or dirty air filter, MAF sensor, or throttle body.
Fuel - bad Fuel pump pressure, or filter.
Exhaust - Bad catalytic converters.
1999 GMC Envoy Transfer case removal Bootsm Jimmy 0 12-05-2010 09:16 PM
Envoy is "chugging" and smells like gas RonK99 Envoy 2 08-04-2010 01:24 AM
04 Envoy Battery light stays on mattwiant Envoy 2 04-28-2010 08:26 PM
envoy 2005 rear a/c not working front a/c only throws cold air that can't be regulate MakeupBoricua Envoy 3 07-11-2009 02:55 PM
Envoy Fan WesPomp Envoy 3 03-31-2009 03:28 PM
