Old 07-10-2011, 04:16 PM
bungea bungea is offline
whistle from air intake?
I have a 97 grand prix 3.8 vin k. I installed an air intake chrome tube with a k and n filter to replace the stock. Since the switch i where a whistling sound. took the air filter off for a brief amount of time and still does it. It sounds like its coming from where the filter and the tube connects. I made sure the connection was tight with the rubber fitting. any help would be great.
Old 07-10-2011, 06:28 PM
danielsatur danielsatur is offline
Re: whistle from air intake?
Doe's it throw a DTC P0171 - Lean code
You might beable to use a little silicone sealent for install.
Old 07-10-2011, 07:32 PM
no codes are being thrown.... just the whistle noise.
Old 07-10-2011, 08:41 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Check the large vacuum line coming off the front of the throttle body.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-10-2011, 11:05 PM
what does the vacuum look like and what am i suppose to look for exactly. i looked at the t line and didn't see any sign of a hole ect.
Old 07-17-2011, 05:19 PM
williz57's Avatar
williz57 williz57 is offline
does this intake have a back-fire relief valve on it? The can be cruddy and if a intake pop occurs it may not seat properly. They are usually opposite end of the intake.
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 03:48 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 06:11 PM
Noise from air intake Kbrickman Cavalier Problem Diagnosis 0 01-12-2009 06:59 AM
Whistling from aftermarket intake TalonEclipseMixGsx Eclipse Problem Diagnosis 4 09-28-2006 09:34 PM
Humming from air intake WILLyyZ Crown Victoria 3 01-12-2004 11:26 PM
