| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Whistling from aftermarket intake
I just put on an aftermarket intake on my 98 Eclipse GSX. Thats the 1st mod ive done to it so far. It deepened the sound of the turbo, but when it gets to around 3500 rpm or so it will start to make a whistling noise kind of like a tea kettle. It didnt do this before when i had the stock intake on plus i checked to see if there was any play on the turbine in the turbo and there wasnt, so i dont think the turbos goin just yet. Is this normal or something i should be worried about? Thanks
Re: Whistling from aftermarket intake
It's probably more a pronounced spooling whine, especially if you added a metal pipe to the intake filter as an upgrade. I wouldnt worry about it...by the way, our cars make a lot more noises than that, so be on your toes
yea mine did something like that but it was just a tiny tiny boostleak. I would recommend just checking to make sure the band clamps are tight enough. Its nothing serious no worries.
also; respect to you for using the proper subforums and asking a legitimate question on your first post!
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Sounds most likely like a leak somewhere. Probably the turbo trying to suck air through a tiny crack in the intake where it isn't sealed up good. Like said above me check all clamps and seals to be sure they are tight and on correctly. Oh, and welcome to the forums.
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
Thanks yall i appreciate it. I ended up takin the rubber connector off from the intake and the turbo and reinstalling it and that took care of the noise. I just bought this eclipse dead stock with no upgrades at all, and im new to turbos, this bein the first one ive owned. I plan on making an upgrade every paycheck so im sure ill have other questions later on, but thanks for the quick advice
