Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-10-2011, 11:38 AM
davisia davisia is offline
Smoking at startup, can't find any straight answers!
I have a 1993 Camry LE 4-cylinder sedan. My car will billow out white smoke when I start it after it's been sitting for awhile (overnight or longer), and it'll last maybe 5 seconds max, then it's perfectly fine. The car runs fine, I'm just sick of the smoke. I've looked around on the internet about the problem, but I'm seeing mixed answers, such as disagreement on the color that oil or coolant burns (blue or white, I'm seeing both colors for both fluids!). So could I please get a straight answer at what it could be?? It's straight white smoke, not steam, no blueish color or anything. Also some of the smoke will seep out from under the hood too, is the exhaust somehow backing up into the engine.
My oil is a tad low, due for an oil change in about 1000 miles. The coolant tank is almost empty, but it's the overflow, so it's not a big deal, right? The radiator does have coolant in it. Any help would be appreciated!
Old 07-10-2011, 12:16 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Smoking at startup, can't find any straight answers!
You are burning coolant. There is probably a small leak in the head gasket into the cylinder which burns on startup. Do a hold pressure check on the cooling system and a compression check on the cylinders.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-10-2011, 12:22 PM
I was thinking it was that, but the smoke doesn't have a "sweet" smell like I thought it would. I've actually had a cracked head gasket before and the smoke did smell sweet at that time.
Old 07-10-2011, 12:25 PM
Also are these tests that you're referring to something I can do at home with basic tools along with not being too good with cars?
Old 07-10-2011, 06:20 PM
danielsatur danielsatur is offline
Is the coolant expanshion tank contaminated with oil?
Is there a coolant shortage?
Is there coolant in the engine block?
If yes, consider using Blue Devil head treatment.
Old 07-10-2011, 07:48 PM
The overflow was empty, but the radiator was full. Went to put more antifreeze in and nothing would go in. Of what I could tell, there wasn't any oil in the overflow. And I have no idea how to check if there's coolant in the engine block. I'm not seeing any evidence of a broken head gasket: no bubbling in the overflow, no milkshake-colored oil, no overheating at all, nothing. Smoke comes out when it starts, and after that, nothing's wrong.
Old 07-10-2011, 08:14 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
There are chemical tests for hydrocarbons (exhaust gases) in the coolant that a car owner can do themselves at home. This will tell you if you have a bad head gasket or cracked block. These test kits are available at most auto parts stores and run about $25. Go to your local auto parts store and ask about their availability and how to properly use them.
Mike
Old 07-10-2011, 09:22 PM
Brian R.'s Avatar
Resident Chemist
You can buy a compression meter relatively cheaply and use it yourself. You get the engine to operating temperature and remove all the plugs inserting the compression gauge into the plug holes one at a time. Crank the engine for a couple of seconds until the compression reading stabilizes.
I'm not sure about the availability of a coolant testing meter, but I bet they're around for cheap. You just have a pump and gauge. Pressurize the system at the radiator cap and watch to see if the pressure drops over time.
Old 10-19-2011, 01:58 PM
bowman646 bowman646 is offline
Another question you should ask. Is the oil level slowly going down after a certain amount of time.
I have found that the valve seals are bad, which causes this type of smoke only when started.
My truck broke down and I can't get a straight answer luthen Problem Diagnosis 10 05-30-2009 11:07 AM
Can't get a straight answer... 4GZChatch '88 - '91 Civic | CRX | Wagon | Shuttlee 7 09-20-2003 01:44 PM
Damn, Now I have cash and can't find any decent 240s :( Grendel 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 14 04-18-2003 08:35 PM
can't find any affordable performance rotors for 95 SE 5 lugs TatII 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 13 09-08-2002 11:33 PM
I can't find any Initial D??? BlueDestiny Initial D 2 07-12-2002 02:37 AM
Tags
blue , smoke , start , startup , white
