Old 07-09-2011, 05:22 PM
ChevyMan99 ChevyMan99 is offline
Put SOME brake fluid in the power steering reservoir
I made a dumb, and embarrassing mistake....I did not fill the res completely with brake fluid, I realized my mistake almost immediately, but some did get in there. I topped it off with power steering fluid....will it be ok, or will I have to flush the entire system? The reaseon I ask, is because I know it's ok with some cars. I have a 99 chevy cav...HELP! Thanks.
Old 07-09-2011, 06:07 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Put SOME brake fluid in the power steering reservoir
Oh dear!
I hope you haven't driven it yet, or even turned it on?
The two fluid types are quite different, enough brake fluid in the power steering could damage parts in the rack through lack of lubrication.
If you haven't driven it yet, or even turned it on, then you can drain the reservoir by removing one of the lines from the bottom.
Flush some new, clean power steering (or ATF) fluid through just to make sure it cleans out all of the brake fluid.
This should solve your problem
If you have started it, or driven it, then you have a much bigger problem as it will have mixed the fluids together and pumped them through the system.
To fix that you need to drain the whole power steering system and flush it several times with new clean power steering fluid.
Good luck, and let us know what happens.
The Following User Says Thank You to Moppie For This Useful Post:
ChevyMan99 (07-10-2011)
Old 07-09-2011, 08:11 PM
danielsatur danielsatur is offline
It might be time todo a flush on both the power steering & brakes.
Old 07-09-2011, 10:33 PM
Thanks, luckily I have not driven it yet and I plan on flushing and refilling the reservoir tomorrow. I'll let you know how it goes!
The Following User Says Thank You to ChevyMan99 For This Useful Post:
Moppie (07-09-2011)
Old 07-10-2011, 04:53 PM
I just got finished siphoning the contaminated fluid completely from the reservoir, then drained what was left out of the return hose. It's all filled up now with fresh fluid. Lesson learned....pay attention!! Lol, thanks guys.
Old 07-10-2011, 08:41 PM
BTW, how would I go about saving a signature for each post ie. make, model of my car? Thanks.
Old 07-11-2011, 12:37 AM
Moppie's Avatar
Master Connector
Just glad you caught and were able to fix it
To edit your signiture, go into "User CP" and click the link on the left called "Edit Signature"
Old 07-11-2011, 07:45 AM
Thank you, and the car is running great!
'99 Chevy Cavalier 2.2L OHV engine auto trans
Moppie (07-11-2011)
HELP! put BRAKE fluid in POWER Steering!! bobby999gib Engineering/ Technical 18 10-16-2015 07:20 PM
Brake Fluid in Power Steering, HELP!!! Jeeskate Jimmy 4 04-21-2010 07:53 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
brake fluid in power steering schoggins Caravan | Voyager 1 09-26-2007 04:52 PM
I'm a dummy, brake fluid in power steering resevoir! loubeemtn Engineering/ Technical 1 07-10-2007 10:31 AM
