Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-09-2011, 03:20 PM
vinnievv vinnievv is offline
Question 1988 Caprice problem with ignition switch
Help,
I'm having trouble with the ignition switch. This past week it is getting harder to unlock the steering wheel by trying to turn the key. Even when I move the steering wheel a little while it is locked and at the same time try to turn the car on the ignition switch won't turn. It took me around 15 minutes today to get the key to finally move the switch to turn the car on. Right now I shut the car off in park and I have to make sure that i don't put the key in the locked position. I have to leave the key in the ignition switch and lock all of the doors then i have to use my spare set of keys to open the door if i want to drive the car. I know sooner or later i will forget and turn the key to the locked position. Is it hard to change the ignition switch and does the 88 Caprice have air bags? I appreciate any help you could provide., Thank you,
Vinnie
Old 07-09-2011, 04:23 PM
jdl jdl is offline
Re: 1988 Caprice problem with ignition switch
Are you talking about the lock cylinder or the ignition switch, these are separate issues. My info didn't show an airbag, but, safety is your responsibility.
The info below is for lock cylinder.
The Following 2 Users Say Thank You to jdl For This Useful Post:
Moppie (07-09-2011), vinnievv (07-09-2011)
Old 07-10-2011, 07:21 AM
j cAT j cAT is offline
Originally Posted by vinnievv View Post
Help,
I'm having trouble with the ignition switch. This past week it is getting harder to unlock the steering wheel by trying to turn the key. Even when I move the steering wheel a little while it is locked and at the same time try to turn the car on the ignition switch won't turn. It took me around 15 minutes today to get the key to finally move the switch to turn the car on. Right now I shut the car off in park and I have to make sure that i don't put the key in the locked position. I have to leave the key in the ignition switch and lock all of the doors then i have to use my spare set of keys to open the door if i want to drive the car. I know sooner or later i will forget and turn the key to the locked position. Is it hard to change the ignition switch and does the 88 Caprice have air bags? I appreciate any help you could provide., Thank you..
Vinnie
the problem you have is , as mention by another member , a lock cylinder issue. the key is required to have sharply cut edges/teeth.. most owners fail to have a new backup key to troubleshoot and make new keys.
using an old worn key will over time damage the lock cylinder.. this may be your problem ..could also be from , just the keys you have , were made by some hardware store with very poor cutters/quality.
the lock smith is the person you need to make a new key for your vehicle. the use of a spray lube to clean out the slot and lube the cylinders may help.Use the straw attachment to blow in the lube. over time dust grime can mess up the lock cylinder...
The Following User Says Thank You to j cAT For This Useful Post:
vinnievv (07-12-2011)
Old 07-12-2011, 08:24 AM
Smile Re: 1988 Caprice problem with ignition switch
Thank you so much for your replies. I did try both keys and had the same problem but then I sprayed WD-40 as you suggested and I was able to unlock the wheel and start the car
Thank you both for your replies!!!
Vinnie
Old 07-12-2011, 09:59 AM
jdl jdl is offline
Good job with the spray.
The Following User Says Thank You to jdl For This Useful Post:
Old 07-12-2011, 08:27 PM
Vinnie
most likely some dirt got to the tumblers..
Old 07-13-2011, 10:49 AM
j cat and jdl,
In your opinions do you feel that the tumblers should work o.k. now? The spray fixed the problem and I was able to unlock the steering wheel but I am still hesitant about turning the key again to the locked position. I know I won't know until I try it but wanted your opinions first
Thanks again for both of your help
Vinnie
Old 07-13-2011, 01:32 PM
inafogg inafogg is offline
j cat and jdl,
Vinnie
hey vinnie,like mentioned tumblers were stuck from dirt. u should be ok
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
vinnievv (07-13-2011)
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 08:41 AM
Having problem with car. thepie Regal 1 05-18-2009 10:39 PM
determine posi for 88 caprice youngwit88caprice Caprice 0 04-24-2009 03:58 PM
1988 caprice problems sm88/4bbl305 Caprice 4 10-24-2005 03:06 AM
Car will only run with ignition switch on Start position Nyquist2000 Accord/TSX/Accord Hybrid 3 09-07-2004 10:06 AM
