Old 09-06-2004, 09:41 PM
Nyquist2000 Nyquist2000 is offline
Car will only run with ignition switch on Start position
I have a 93 honda accord which will only keep running if I hold the key on start position. If I let it go the, engine shuts down. I have noticed that the clock doesn't come on when the ignition switch is in the ACC position. It will only come on when the ignition is in the start position.Could this be a swich problem or starter probem?? Help??
Old 09-07-2004, 08:58 AM
AccordCodger AccordCodger is offline
Re: Car will only run with ignition switch on Start position
NOT a starter problem. I'd say the switch is bad.
Old 09-07-2004, 09:52 AM
94accordVTEC 94accordVTEC is offline
Send a message via AIM to 94accordVTEC
yep, not a starter problem...you might just check the wiring coming from the switch...the "run" position may have a bad wire
Old 09-07-2004, 10:06 AM
But the "ACC" position is bad too, right? So I'd still say it's the switch.
