Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-09-2011, 01:42 PM
help123 help123 is offline
93 jeep grand cherokee limited getting hot 4.0l
I have a 93 jeep grand cherokee 4.0l it is running 210 or hotter , have changed water pump thermostat and flushed it out . But still am having trouble with it getting hot have a 2 core rad. coming and am going to try that, seems like the rad. may be blocked some it shout out of the rad. fill yesterday . I have heard about the head gasket , but am not lossing any water , not out the tail pipe or in the oil or any that i can see , need help real bad will appericate any help thank you have a gr8 day .
Old 07-14-2011, 10:59 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 93 jeep grand cherokee limited getting hot 4.0l
IMHO it's likely the radiator. Your Jeep is over 17 years old. If you haven't changed the coolant regularly then you likely have enough buildup inside the radiator to reduce cooling capacity.
I'm guessing it was fine all winter and has started overheating in the very hot summer we're having?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
The Following User Says Thank You to fredjacksonsan For This Useful Post:
help123 (07-17-2011)
Old 07-17-2011, 04:00 PM
I changed the rad. and it solved the problem , i bought this used from a car lot and had no idea about the rad. but it is running 200 and lower . So thank you for the information and have a gr8 day .
1996 Jeep Grand Cherokee Limited 4WD Dana 44 V8 5.2 neowedge Grand Cherokee | Grand Cherokee SRT8 5 01-20-2005 09:34 AM
Re: 94 Jeep Grand Cherokee Limited Overdrive Problems mitch2005 Grand Cherokee | Grand Cherokee SRT8 2 12-19-2004 10:46 AM
i have a 96 jeep grand cherokee limited edition d.h.r. Grand Cherokee | Grand Cherokee SRT8 1 04-22-2004 09:03 PM
93 jeep grand cherokee limited nw1489 Grand Cherokee | Grand Cherokee SRT8 1 03-24-2004 07:54 PM
1997 jeep grand cherokee limited butch62255 Grand Cherokee | Grand Cherokee SRT8 3 01-26-2004 01:29 AM
