Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-17-2004, 11:28 AM
mitch2005 mitch2005 is offline
Re: 94 Jeep Grand Cherokee Limited Overdrive Problems
Hi. Anyone out there experienced and solved the following problem with their overdrive shifting? I have a 94 Grand Cherokee Limited, 6 cyl, 4wd. Seems whenever the car heats up, the overdrive light comes on and then the car doesn't want to shift out of second gear. So, I am forced to drive 40 mph while the engine is revving at 4k. Obviously, not a good situation. Already had the tranny rebuilt. Mechanic is not sure of the problem.
Any answers out there? Thanks, Mitch
Old 12-17-2004, 11:48 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Re: 94 Jeep Grand Cherokee Limited Overdrive Problems
your transmission is overheatign check the cooler lines to make sure theys are not clogged.
whenever the Transmission overheats it shuts the OD off to try to keep the transmission cool, and that is why your not shifting out of 2nd as well.
Check the tranny cooler lines/radiator to make sure the are not clogged.
Old 12-19-2004, 10:46 AM
Thanks for your input...I will explore this direction.
