Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-20-2004, 06:10 PM
butch62255 butch62255 is offline
Question 1997 jeep grand cherokee limited
can anyone tell me why my left turn signal blinks really fast sometimes and normal other times? also how to replace my check engine light ,it seems to have burned out?
Old 01-20-2004, 06:12 PM
Re: 1997 jeep grand cherokee limited
any input would be greatly appreciated
Old 01-20-2004, 08:25 PM
MACspeedTUNER MACspeedTUNER is offline
bulbs and such
usually when a turn signal blinks rapidly, its a sign that one of the bulbs has burned out or has lost a connection. what is likely happening is that one of your bulbs has a loose connection in the socket. Pull the bulbs and make sure that the connections are clean and free of rust. I dont know how your check engine light "burned out". The light can go on and off if the computer has set an intermittent code. The "bulb" is generally an LED which is a solid state component. They usually dont blow out. replacement would require removal of the gauge cluster.
Old 01-26-2004, 01:29 AM
twa8080 twa8080 is offline
ok lemme guess.. i blinks regular when your lights are off.. and it blink fast when your running lights are on.. the cause of that is prob u got a light bulb that is burnt out.. on the side that blinks fast.. most likely in the front..
