Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-26-2004, 04:01 PM
kilmurray1 kilmurray1 is offline
engine reving high not changing gears
engine revs high but car is going quick...like the tranny isn't up to speed.....this goes away after a few miles, but it is quite annoying, and I imagine its not good for the car...
Old 05-26-2004, 04:53 PM
AZFlyingDiver AZFlyingDiver is offline
Re: engine reving high not changing gears
Any error codes? If you don't have a reader or don't know the "key on key off a few times" trick, you can have AutoZone / Checker read your computer for free. My guess would be the TCM (transmission control module) - only a guess, though...
Old 05-26-2004, 05:06 PM
mjgjr72 mjgjr72 is offline
check your fluid level in the trannsmission first, may be low, as fluid heats up and expands symtom goes away. or fluid may be old and and sludgy may want to try flushing, if fluid is brown and smells burnt you may have an internal problem, like burnt clutch packs.
Old 05-27-2004, 12:09 AM
95Orvis 95Orvis is offline
Check your Vehicle Speed Sensor. Just replaced mine. My 95 JGC 5.2L would not shift into overdrive and was running 50% higher RPMs. Parts are cheap($50-$60 sensor & housing adapter) and repair is easy (30minutes) if you get the same connector. The sensor is on the back end of the transfer case near the drive shaft to the rear wheels. If I remember correctly, it is error code 15.
To check for the error code, turn your ignition On-Off, On-Off, On then count the times the Check Engine Light blinks. There are short pauses between digits and long pauses between multiple codes. The last code it will give you is 55 which means that is the end.
Good luck,
Old 09-15-2004, 12:01 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
check the Throttle Valve cable, I had this problem, in my 94 Grand cherokee 5.2L, the tip that connects the TV cable to the throttle body broke, and it wouldn't shift at all just rev real high, i was forced to drive form the garage to my house only a block away at 10 miles an hour, b/c I didn't want to hurt anything.
Old 09-15-2004, 09:58 PM
xj31 xj31 is offline
does it shift if you let off the gas?A very common thing is the t.v. cable or the lever on the trans gets rusted and sticks.make sure that it moves freely.if it sticks try some kind of rust penetrant.Another common item is that the front clutch seals inside the trans could be worn out.that makes it not want to shift from 2 - 3
Old 07-03-2007, 11:03 AM
a39raven a39raven is offline
Just fixed this same problem on my 98Grand Cherokee-Went to Advance Auto and put it on their dash plug-in analyzer(Afree service). The code read speed sensor, which I bought for a relatively cheap price and changed out in 10min. tops.It is on the bottom of the transmission. "Problem Solved". They then had to reset the engine's computer.
