Go Back   Automotive Forums Car Chat > Plymouth > Breeze
Old 07-09-2011, 11:22 AM
moneyinc moneyinc is offline
Angry 96 Breeze No Spark
I have a 96 breeze 2.0 engine it was running fine but now won't start changed the plugs,ignition coil, and crank sensor but it still won't start and I'm getting no spark still really don't know what else to do is there someone out there who can help me cause I really could use the help
Old 07-09-2011, 12:11 PM
jdl jdl is offline
Re: 96 Breeze No Spark
Check primary voltage at the coil pack, dark green wire with orange tracer, Should be hot with engine cranking. Any applicable trouble codes? You may be able to get some codes by cycling the ignition switch. You turn the key just till the dash lites come on, no further. Cycle the key on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
The computer has to see both the cam and crank sensor signal, or it won't energize the asd relay.
Old 07-09-2011, 12:46 PM
Thanks I'm gonna try that to see what happens
97 Breeze won't start Jennaelisabeth Breeze 1 08-11-2010 05:21 PM
97 Tahoe won't start. Cranks, has no spark rookieshaper Tahoe 2 02-24-2009 10:40 AM
91 jetta sparks on plugs only when turn key to on mybestconnect '91 - '96 1 02-18-2009 08:56 PM
spark plugs freakyfire05 ZX2 2 02-17-2009 12:03 PM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 09:19 PM
