Old 07-08-2011, 12:40 PM
Neunundneunzig Neunundneunzig is offline
Has My Clutch Gone Out?
Hey guys, I started my day normally until I went to the garage to start my car. Upon entering the car, I noticed the clutch was feeling a bit strange. Disregarding this, I started my car and attempted to back out of the garage until I noticed I was unable to put my car into any gear.
The shifter goes through the gears without any problems while the car is off, but not while running, thus leading me to believe the clutch is to blame. I've also noticed the clutch feeling different for quite some time, though I shrugged it off as my own paranoia.
What do you guys think? The car is about nine years old with 56k miles.
Old 07-08-2011, 01:19 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Has My Clutch Gone Out?
Since you posted in a general forum (not vehicle specific) it would help if we were informed of the vehicle year, make and model. But, then it may also make more sense to post in the vehicle-specific forum as others may have encountered exactly the same symptoms on that same car and know what it takes to fix it.
Does your car has a hydraulic or manual/cable clutch? If hydraulic, it may need to be bled or the clutch master cylinder may be failing. If manual, the cable may need to be adjusted.
-Rod
Old 07-08-2011, 02:53 PM
Thank you, I never thought of that. I'm new to the forum so you'll have to forgive me.
Old 07-08-2011, 06:45 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
No worries, and welcome to AF
What model car is it?
It does sound like either the clutch needs adjusting, or if it's a hydraulic one, something has failed.
Old 07-08-2011, 08:48 PM
shorod's Avatar
SHO No Mo
Looks like it's a 2002 Elantra. The new thread can be found here..
-Rod
The Following User Says Thank You to shorod For This Useful Post:
Moppie (07-08-2011)
Old 07-08-2011, 09:43 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Inspect the HYDRAULIC clutch slave cylinder. Replace it if you see fluid at the rubber boot.
I think my alternator has gone out. ss101504 Caprice 6 01-28-2010 08:17 AM
Clutch gone out??? buddinbuddin Ranger | Courier 6 01-12-2004 11:33 AM
PETA has officially gone too far TexasF355F1 Stress Release 33 03-17-2003 04:00 AM
Unfortunate news: Twoguysracing.com has gone out of business... daggerlee Car Modeling 4 02-24-2003 05:50 PM
