Old 07-07-2011, 04:43 AM
USAmade USAmade is offline
Throttle Body Whistle
So i just rebuilt my stock OEM carb/throttle body in my 1989 Chrysler Fifth Ave. 318 5.2 2bbl. I rebuilt it because I had a vacuum leak because the dbag who owned the car before used an adhesive on the gaskets... What a tool right? Well after the rebuild I no longer have any vacuum leaks, but my throttle body whistles when I step on the gas. When I'm at a constant speed it doesn't whistle, and when I'm accelerating past 70mph it doesn't whistle. I think it might be my idle control valve, but I'm not sure. Does anyone know why this is happening?
Thanks.
Old 07-24-2011, 07:47 PM
jamesslcx jamesslcx is offline
Re: Throttle Body Whistle
Hi USAmade, hope its not too late to reply. If you have a carb the whistling is most likely coming from the throttle plate or throttle shaft which are probably worn....not a major issue but if it bothers you its replacement time.
Old 07-25-2011, 02:14 AM
Eh, replaced chock thermostat and the problem was gonskies. Thanks though!
Throttle body - cruise control paraip Element 1 02-09-2011 10:00 PM
Metal Filter at Throttle Body thetenfold Regal 5 02-06-2011 09:48 AM
?? about a throttle body mod thread 4x4chevymanS10 Performance 4 09-20-2009 10:32 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 06:11 PM
bbk 85mm throttle body whistle??? jeff983000gt F-Body Problem Diagnosis 1 06-27-2008 02:30 AM
