Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-03-2011, 01:01 PM
thetenfold thetenfold is offline
Metal Filter at Throttle Body
I removed the air intake tubing, and right at the front of the throttle body is a metal mesh filter. Can and how do I remove it?
(an image of it is attached).
Old 02-03-2011, 07:02 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Metal Filter at Throttle Body
It really isn't a filter. It is an air difuser that creates turbulance in the air stream to better atomize the air and increase power. You can remove the screen by removing the metal ring on the outside of the screen. However, you may find that the car will not run as well once you remove it.
Old 02-04-2011, 09:56 AM
I only want to remove it to clean the throttle body, I would put it back on if I could get it off.
Old 02-05-2011, 02:31 AM
smonroe86 smonroe86 is offline
Once removed, cleaned and replace, are we still talking any further issues? I was thinking the same but instead I just sparyed it down till no more dirty fluid and it was straight clear afterwards.
Old 02-05-2011, 12:17 PM
I was advised to take the sensors out (iac, iat, maf, tps), take the throttle body off the intake manifold, clean it with the tb off, dry it, and put it back on.
Old 02-06-2011, 09:48 AM
BNaylor's Avatar
BNaylor BNaylor is offline
To remove just remove the C-Clamp/snap ring. You can use snap ring pliers or a small screwdriver. Be sure to re-install or you may get MAF sensor issues or an erratic idle.
Timeslip 08/12/06
AF Community Guidelines
Tags
body , filter , mesh , metal , throttle
