Old 07-06-2011, 06:56 PM
BetoBrazil BetoBrazil is offline
Yamaha YZR-M1 Valencia 2005
Hello everybody AF!
I'm a Brazilian modeler and my favorites are motorcycles kit scale 1/12.
While monitoring the work of the Forum for a while now, this is the first topic that I display my assemblies.
How not mastered the language, I will use a translator, but I hope you can understand my writing.
Today I share with you my current mount, the beautiful YZR-M1, presented at the end of the 2005 season at Valencia, piloted by Valentino Rossi - already known here in the Forums by other beautiful works.
To start, the kit used and the major enhancements, including the Super Detail-up set of Top Studio. The kit is Colin Edwards but the decals will be exchanged for the VR46.
Here the main reference for how I plan to leave the motorcycle
Particularly for these bikes (M1's), seeing many kits assembled by the world, especially when presented without an enclosure, as in the version I intend to do, a piece especially draws much attention, especially for golden highlights to the engine, which is the cap clutch. Thus, I decided to start applying some technical improvements to this part:
Original part of the tree
Opening of the bolts gradually to maintain a thin plastic along with the new finish
Application of tape in PE with ventilation holes
Order now and perforated PE applied. The plastic center screw was also removed.
Platelet in gold paint and application of light to highlight Clear Orange
Modeling clay mask to receive the new color on body
Paint Gun Metal Metalizer of Model Master
Here components of terminal T2M completion of cables that will replace the screws on the plate
For best finish, the pieces were "polite" in micro-grinding
Difference between the original pieces (3 left) with polished (3 right) with sandpaper 2000)
New "components" ready for mounting. Central axis of hypodermic needles and 1.0mm nut T2M "extended" the bit and painted red and clear. PE rivets already pasted.
Finally the "new" clutch mounted
Comparison
Here an update of the assembly, after the clutch, I decided to face the desk set, handlebars and grips.
Finally, the first pre-assembly (no screws and PE) with all parts made / worked and comparison with the original parts
Levers open ...
Levers closed ...
Hope you enjoy and that the difference in language does not hinder our knowledge exchange.
As I said, not mastered the language then use a translator for this, but if anyone has any questions let me know that I will be pleased to answer, OK.
Beto (Brazil)
The Following User Says Thank You to BetoBrazil For This Useful Post:
markiii (07-06-2011)
Old 07-06-2011, 09:40 PM
YongGun Park YongGun Park is offline
Registered User
Re: Yamaha YZR-M1 Valencia 2005
WOW... looks great.
Old 07-06-2011, 09:41 PM
markiii markiii is offline
Very nice! Where did you get your reference photos?
Old 07-07-2011, 04:47 AM
Mr. Jekyll's Avatar
Mr. Jekyll Mr. Jekyll is offline
Awesome start!!! Excellent details!!!
Looking more progress.
Old 07-07-2011, 06:04 AM
hildengarde hildengarde is offline
Pfiouuuu, it makes THE difference.
Amazing job, can't imagine the final step !
Old 07-15-2011, 04:54 PM
Doc305's Avatar
Doc305 Doc305 is offline
Bom trabalho Beto, se precisar sou muito bom de ingles e um pouco de portugues...
Keep up the great work
Old 08-16-2011, 09:27 AM
YongGun Park, markiii, Mr. Jekyll, hildengarde and Doc305
Thank you for the comments and compliments!
markiii
All photos are from Internet references and Pit Walk Photo Collection. If you need any details let me know
Doc305
Por favor me corrija sobre qualquer erro na escrita. Obrigado!
Guys, new update. Set of handlebars 95% ready, lacking only the reservoirs, wires and cables.
After you run the idea of the hoods, it was time to paint and detail the set screw. Basically all the pieces went to Primm, painting,
drilling and fixing.
The first thing I thought needs to be addressed was the tip of the suspension (canes) on the table, despite being regulated according
to track conditions, the references I have for this race shows that the scale they would be much lower than the reference kit for the
Tamiya FrontFork Set. The parts are aluminum and I decided to lowered.
Compared the pre-assembly
After glued a plate and screws philips PE of 0.7 are posted
Mounting the levers. Spring + shaft + pin.
Final result
To conclude, I thought the best way was to show how the idea of the hoods would be a video. Click on the link to view YouTube.
Hope you enjoy.
http://www.youtube.com/watch?v=8hoa9szS6WY
Beto
markiii (08-18-2011)
Old 08-16-2011, 04:51 PM
robrex's Avatar
robrex robrex is offline
Great work!
Rob
Old 08-17-2011, 02:04 AM
Wita's Avatar
Wita Wita is offline
Send a message via ICQ to Wita
Excellent work!
Old 08-18-2011, 04:32 PM
Martini Man's Avatar
Martini Man Martini Man is offline
wonderful work !
above and beyond anything I've seen done to a motorcycle kit.
looking forward to the whole build.
Paul
The Following User Says Thank You to Martini Man For This Useful Post:
modellerone (08-29-2011)
Old 08-19-2011, 12:03 AM
markiii
All photos are from Internet references and Pit Walk Photo Collection. If you need any details let me know.
Beto
That is fantastic!
And how is the PitWalk Collection for 2005? I wanted to buy a copy, but too expensive or hard to find.
I wanted details of the motor, especially behind the cylinder bank.
Old 08-19-2011, 02:25 PM
modellerone modellerone is offline
hey,
great work,
what spring did you use?
Marcel
Old 08-20-2011, 01:44 AM
sportracer02's Avatar
WOW, what you make on the levers are models themselves !! Fantastic !!
Micha
Old 08-20-2011, 02:03 AM
Mr. Jekyll's Avatar
Absolutely brilliant!!!
Old 08-20-2011, 12:34 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I can't believe the amazing realism and attention to detail. I think that is the most detailed set of handlebars I have ever seen. Between the clutch, and the handle bars, I think each part will be a model in itself.
-Mike
YAMAHA YZR-M1 2006 CAMEL No.46 YongGun Park Completed Projects / Gallery 31 10-07-2012 02:32 AM
Fiat Yamaha YZR M1 Valencia paddock exhibition 2007 geronimo77 WIP - Motorbikes 1 06-27-2010 08:32 PM
Tamiya Yamaha YZR-M1 Valencia Edition generationx Completed Projects / Gallery 5 09-26-2008 03:26 AM
Rossi Yamaha YZR-M1 Valencia '05 geronimo77 Completed Projects / Gallery 8 04-29-2007 02:43 PM
Yamaha YZR-M1 Valencia Edition Ole_L WIP - Motorbikes 58 04-08-2007 05:12 AM
