Old 07-06-2011, 05:14 PM
scarecrow0529 scarecrow0529 is offline
shift rod laying on ground
i have an 89 honda crx and the shift rod is laying on the ground. i rigged it back together and now only get 3rd and 4th gear. should i just replace the spring pin and retainer or replace the whole transmission.
Old 07-06-2011, 10:24 PM
BullShifter's Avatar
Re: shift rod laying on ground
Replace the pin unless you feel you need to replace the trans.
Old 07-07-2011, 06:59 PM
thank ya sir i think that is where i will begin. i will report back.
Old 07-09-2011, 06:57 PM
i used stainless steel m8 x 35 bolt with lock nut and a couple washers. it now shifts better than it did before. thanks for the help.
Old 07-09-2011, 07:33 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
How did it end up setting on the ground?
Nothing wrong with using a nut and bolt, would be easier to pull out in the future than the pin and retainer used by Honda.
shift rod hanger friz15 Type 1 1 03-06-2005 03:59 PM
help replacing shift rod bushing on 71 super beetle 71SuperBeetle Type 1 4 12-07-2004 09:58 PM
Shift rod trouble projectgsr Let's get Technical! 3 11-17-2004 12:29 AM
Shift rod problem?? HELP corydeeznutz MR2/MR-S 12 07-01-2004 06:36 PM
