Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-16-2004, 12:10 PM
projectgsr's Avatar
projectgsr projectgsr is offline
Shift rod trouble
I'm in the process of removing the transmission out of my 95' GSR 5 speed. But I'm having alot of trouble getting the spring pin out of the rod on the end that conects to the transmission. Chiltons says to tap it out but there isn't a whole lot of room and besides the end of the pin is mushroomed over. I tried using a chisle and even a tap. My friend who works on american cars suggested drilling the pin out so I even tried that but broke two bits and didn't even get it out. Please somebody help.
Old 11-16-2004, 10:13 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
use a punch but use a flat head punch because if you use a pointed one you will just push open the pin and it will not come out.
and what do you mean mushroomed over, its a cylinder metal pin, how can it mushroom. do you really need to take it out too. i pulled my d series tranny out without removing hte rod
Team Lonely Drivers
Old 11-16-2004, 11:25 PM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
Re: Shift rod trouble
try grinding off the "mushroomed" part with a dremal tool or something and tap it out like civickiller said but tapping it out is the only way ive ever heard or done but i used a small flat head
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
Old 11-17-2004, 12:29 AM
i couldnt get mine by tapping it with a punch so i used a gear puller and pushed it out. broke my gear puller but i got hte pin out but i couldnt pull the rod off because it was rusted on there so i ended up just taking the rod out with the tranny. broke my gear puller for nothing
Team Lonely Drivers
