Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 07-06-2011, 04:24 PM
Mechmark Mechmark is offline
98 malibu 3.1 hard starting
I have installed new plugs and gas filter. doesnt do it all the time, but does seem to be a little worse when warmed up. fuel pressure is good. pulled vacuum hose off of regulator and it is not leaking. do the injectors on these give many problems?? Any help is appreciated
Old 07-06-2011, 11:35 PM
Johnny R Johnny R is offline
Re: 98 malibu 3.1 hard starting
Could be just the age. When I first bought my '99, I only had to look at the key and it would start (in a manner of speaking). Now, it cranks and cranks. sometimes I imagine if I pump the gas pedal when the key is turned on, it starts faster. But I dunno. It has 210,000km (~130,000 miles).
Johnny R.
2011 Malibu LT - It's a beaut. So was my '99!
2006 GoldWing 1800 cc - the way to go, coast to coast!
Old 07-07-2011, 12:22 PM
rkvons's Avatar
rkvons rkvons is offline
It could be that your injectors are leaking. When you shut your car off, there is fuel pressure in the fuel rail. If this leaks into your engine from the injectors, it will be hard to start. You can put a fuel pressure gauge on the fuel rail and see if the pressure goes down kinda quick when you shut the engine off. Wait about 10-15 minutes and see if it is hard to start. Then repeat the process, but as soon as you shut the engine off, release the pressure in the fuel rail, wait the same amount of time and see if it is hard to start. If they are leaking, you will probably have to get them cleaned professionally.
1994 Ford Explorer Hard starting after it sits. privottfamily Explorer | Explorer Sport Trac 3 05-01-2012 05:14 PM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 04:21 PM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
