Old 07-06-2011, 04:22 PM
kurtl's Avatar
kurtl kurtl is offline
Send a message via ICQ to kurtl
Prototyp Tyrrell P34 „Silverstone“ 1/12
Hello Modelfriends,
Some time ago I built the prototype in Silverstone 1 / 20, perhaps still remember which.
Now that the P34 is my declared favorite model, it is almost a must for me to realize this extraordinary Tyrrell also in 1 / 12.
I have decided to build a prototype parallel to the 77 P34. I am surprised that in this scale can be more easily accomplished than those enclosed in 1 / 20 * gg *.
In the conversion I am again a little on 1/20er model oriented as to original recordings of Tyrrell's.
I used mainly plastic sheet panels.
Lg
Kurt
Old 07-06-2011, 04:26 PM
hildengarde hildengarde is offline
Re: Prototyp Tyrrell P34 „Silverstone“ 1/12
Perfect job.
A unique kit in your collection
Old 07-06-2011, 10:56 PM
kurtl's Avatar
It continues with the air box,
Basic requisites are 1mm plastic plates
After much sanding..........
to check……..
A coating Tamiya putty..............and sanded
Lg
Kurt
Old 07-07-2011, 03:05 AM
flhansen's Avatar
flhansen flhansen is offline
Yes another P34. Subscribed.
Flemming
Old 07-07-2011, 04:05 PM
nipponts's Avatar
nipponts nipponts is offline
The making of airscoop is amazing
Old 07-08-2011, 02:49 PM
kurtl's Avatar
We continue with the expensive part of the airbox
First, I built a mold of a 0.75 mm plastic sheet plate.
Then the mold was filled with a silicone compound, After some time, I could remove the silicone mold.
For my next steps I need my original form of the Airbox split in the middle, of this I'm already at the beginning of the part so designed that I can take it apart every time.
The first part of my low-drag action started like this, first, 2 double-sided tape strips applied to a surface.
At the lower part of my form still has a 3mm extension attached to the resin subsequently decided to double-sided tape strips by additional fixing.
The next steps then had to go quickly.
First, the mold was filled with resin.
The result was a 0.75 mm thick resin plate.
However, before they harden completely I take from the silicone mold and put it liberally over my half airbox,
, using small plastic card, the thin viscous resin plate to the edges of the air box down on the double-sided tape
,remains in the form received without the resin plate of the airbox can take off again.
After 20 minutes I could cut out the part with a knife around the edges.
And that's the result:
Only the second half as deep drawing and then, the two parts are connected.
Resin is adhered to the top with resin, it connects seamlessly and you get a part as in my case that looks as if it were of a piece.
I would like to sorry for my bad English, I can not live better
Lg
Kurt
Old 07-08-2011, 03:50 PM
robrex's Avatar
robrex robrex is offline
That airbox is great Kurt! I've never seen resin used like that before.
I'm watching this build for sure!
Rob
Old 07-17-2011, 12:45 PM
kurtl's Avatar
Thanks Rob
The chassis plate was Painted with Tyrrell blue from Zero Paint, exactly as the yellow stripe.
The new nose,ready to paint
The airbox has been fixed
Lg
Kurt
Old 08-21-2011, 03:41 PM
kurtl's Avatar
All other body parts are paint.
After the 'nose' her blue Zero Paint color had on it, I made me a painting template for the angular lines of three to ... ..
On the air box was painted a yellow stripe ... ..
On the sides I have to square the three stripes and painting and on the rear wing end plates also come to the yellow stripe painted.
Lg
Kurt
Old 08-22-2011, 02:07 AM
kalax kalax is offline
Thumbs up Re: Prototyp Tyrrell P34 „Silverstone“ 1/12
Amazing! Great work.
Klaus
Old 10-12-2011, 12:31 PM
kurtl's Avatar
The Silverstone prototype is now finished, but not as detailed as the '77 Monaco version but the focus in this version is drawn to the airbox and the "nose".
The airbox was made ​​in my Resin thermoforming method, the wall thickness is about 0.75 mm and the box is completely hollow as the original.
The yellow stripe and the angular lines of 3 was applied with an airbrush.
Lg
Kurt
Old 10-12-2011, 01:34 PM
924_CarreraGTS's Avatar
924_CarreraGTS 924_CarreraGTS is offline
Great work on a unique subject. Very clean!
Old 10-12-2011, 06:15 PM
da_ashman's Avatar
Great Work, looks awesome!!
Old 10-13-2011, 02:22 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Great job, but what impressed me more was the soft resin sheet modeling.... very inspiring and at last the result on the scoop is impressive.
gio
1966 Honda S800 - Doyusha 1/12 edwing666 Completed Projects / Gallery 5 04-28-2010 09:35 AM
Tamiya Tyrrell P34, 1/12 MarcoSaupe Completed Projects / Gallery 2 03-17-2008 04:10 PM
Tyrrell-Ford 1971 1/12 dekbamodel Completed Projects / Gallery 8 03-12-2008 06:14 PM
Tyrrell P34, Tamiya 1/12 MarcoSaupe WIP - Motorsports 9 03-02-2008 12:20 PM
Tyrrell 003 - Tamiya 1/12 Sennake Car Modeling 10 04-10-2003 10:22 PM
