Old 07-05-2011, 07:43 PM
uneekuuuu uneekuuuu is offline
Angry 1994 taurus sho cooling fan not coming on
where is the relay for the taurus sho 3.2
Old 07-05-2011, 07:56 PM
danielsatur danielsatur is offline
Re: 1994 taurus sho cooling fan not coming on
Suspect a bad fuse, relay, sending unit, or fans.
Old 07-05-2011, 09:30 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The electric radiator cooling fan relay is integrated into the Constant Control Relay Module (CCRM). If you turn on the A/C does the fan run? Have you tried hardwiring the fan to see if it will run when powered straight from the battery? The fan motor has three wires going to it. The Black wire is the ground, the Brown/Orange wire is the low speed fan winding , and the high speed winding is the Dark Blue wire.
There's a 50A Cooling Fan fuse in the Engine Compartment Fuse Box and the fan enable lines to the CCRM are pins 14 (low) and 17 (high).
-Rod
Old 07-06-2011, 04:42 AM
Angry Re: 1994 taurus sho cooling fan not coming on
-Rod
hey rod yes i did all the above hard wired the fans and yes they work ive also replaced the constant control relay but where is the cooling fan switch or some kind of sensor that is mounted to the block that sends signel to the module when it heats up right?
Old 07-06-2011, 07:01 AM
shorod's Avatar
SHO No Mo
So does the fan run with the A/C on? Did you check the trigger wires to the CCRM to see if they are giving signal to activate the fan?
The Engine Coolant Temperature (ECT) sensor is a two wire sensor, with a gray/red wire that's reference from the PCM and a light green/red wire that's the sense wire back to the PCM. On the 1994 3.2L SHO, the sensor is located on the top LH side of the engine, below the throttle body. The resistance across the sensor should drop as the coolant temperature increases.
-Rod
Old 07-06-2011, 08:57 AM
Thumbs up Re: 1994 taurus sho cooling fan not coming on
-Rod
no fan when i run a/c did i mention i changed the ckp also dealing with it not starting after it warms up im hoping that the ckp fixed the problem but now the fans ive evrey thing else but the ccrm oh wait a minute i changed that out the old one i was wanting to see what was inside the box so i opened it, inside i found 2 big relays and 2 small ones now i can look into it alittle further knowing witch pin is for fan thanks ill get back to you if you thing of anything let me know
1999 sable fans not coming on long enough, PCM, CCRM. cooling timetrax Sable 5 06-05-2015 08:52 PM
AC cooling issue.. Cooling fans not coming on vwtech93 Intrigue 6 08-26-2008 08:31 PM
Cooling fan not coming on medicmandan Grand Prix 4 06-12-2007 10:44 PM
92 bird cooling fan not coming on(relay replaced) tk6500 Camaro Discussions 1 09-24-2005 12:48 PM
2002 Taurus engine cooling fan wont come on debsco731 Taurus | Taurus Wagon 3 09-07-2005 09:44 AM
