Old 08-16-2008, 02:35 PM
vwtech93 vwtech93 is offline
AC cooling issue.. Cooling fans not coming on
I'm working on a 02' Olds Intrigue and I have charged the AC system to 1.02kgs and still no cooling pressures are at 200 low and 40 high. Compressor kicks on still no cooling my pressures I believe are way out of range due to the cooling fans are not coming on. I have checked all fuses and relays, I have power at the relays ans fuses but no power to the fans. Looked up the wiring diagram and it looks like it is controlled by the PCM. I'm believing that it here where my power id not being transmitted or ground, the circuit is not being completed anyhow.
Anyone seen this before? Have any ideas?? Other than running my own wires.
Thanks, Thomas
Old 08-16-2008, 05:24 PM
harmankardon35 harmankardon35 is offline
Re: AC cooling issue.. Cooling fans not coming on
sounds like a bad compressor, if the system is charged up and the compressor is running, but the lines under the hood don't get cold, then the compressor is likely worn out.
Old 08-17-2008, 09:28 PM
That doesnt expalin why my cooling fans arent working. If my compressor was bad my fans would still work.. The compressor is turning pressures might not be correct but its still turning. So my cooling fans should come on with the AC on
Old 08-18-2008, 02:03 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Do you have digital climate control? If so is your external temperature reading accurate?
In fact, heres an interesting question, do vehicles without digital climate control still have an ambient temperature sensor? It would make sense if they did.
If your sensor is showing a false reading and saying its too cold, the AC wont work.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-18-2008, 06:37 AM
willibc willibc is offline
I am having the same issue. Was thinking it was the PCM as well. Havent' had time to finish working on. If you find a fix. Please post it. I have been trying to figure this out for a while now.....
Old 08-18-2008, 07:56 AM
brcidd's Avatar
brcidd brcidd is offline
GM "W" bodies "wait" on discharge pressure to enable the cooling fans- they come on at 175 psi-- so is your pressure transducer on the high side line (below air cleaner) plugged in-- etc
It is designed like this so the fans don't have to run while driving on the highway..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 08-26-2008, 08:31 PM
Yes, my high pressure switch is plugged in. Thanks though. I'm replacing the AC compressor, reciever drier, and orfice tube.
