Old 09-01-2005, 01:07 PM
debsco731 debsco731 is offline
2002 Taurus engine cooling fan wont come on
hi, all. we are working on a 2002 Taurus, with a 3.0 L engine, and the electric cooling fans will not kick on. there is no Haynes or Chilton manual to be had for this year model car, and we do not know where the fan relays are located. does anyone have any idea where they are? thanks so much, in advance.
Old 09-04-2005, 05:21 PM
Willyum Willyum is offline
Re: 2002 Taurus engine cooling fan wont come on
Maybe it isn't getting hot enough, no? Look at the manual for the '01 is the same for the '02, is the one I've used.
Old 09-07-2005, 01:44 AM
KimMG KimMG is offline
AF - Advisor
Try your local library for a manual. Many libraries have shop manuals that are more detailed than Haynes or Chilton. Also many libraries subscribe to online databases that provide automotive help.
Possible reasons why the fan will not come on:
low coolant level
bad fan motor
no power getting to the thermo switch
bad thermo switch (not closing and allowing power to get to the fan)
car is not running hot enough (is the car overheating?)
bad relays
Old 09-07-2005, 09:44 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Remove the plug, use a test light and turn the A/C on. If current is at the plug, relay is good. If no current., relay is located in the underhood fuse block.
Go here and go to page 163
https://web.msslib.dealerconnection....000c5880287a9f
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
