Old 07-05-2011, 07:06 PM
1994cavalier 1994cavalier is offline
How to fix Exhaust Leak???
I have a 1994 Cavalier 2.2 Liter. I've recently have had an exhaust leak where the flange from the down pipe meets the manifold. After thinking the exhaust leak was coming from the manifold; bc I thought there was a crack in it which there wasn't.The type of gasket thats used is the doughnut type. It is leaking right at this spot.
What could be causing this? the bolts are still good; did not break off or crack at all when I removed them, and the springs still look good...what could be causing exhaust to still leak?? does it need new springs?? im baffled.... does the doughnut gasket have to sit a certain way?? if anyone can give advice it would be greatly appreciated.
Thank you!
Old 07-05-2011, 07:20 PM
danielsatur danielsatur is offline
Re: How to fix Exhaust Leak???
You might consider a local muffler shop, because they got a lift and all the right tools.
Old 07-05-2011, 07:26 PM
thank you for you're input, but that is not needed. i was just wondering why after a new gasket was put into place that this is still happening. ive done all the work myself, better than any shop could do, so why else would it leak?? is what i would like to know!!
manifold and flange and pipe are all in good condition
Old 07-05-2011, 07:38 PM
It could be back pressure from a plugged CAT, a muffler shop can do a back pressure test on your catalytic converter.
If DIY, do a Google ''Youtube Auto catalytic converter test''
The Following User Says Thank You to danielsatur For This Useful Post:
1994cavalier (07-05-2011)
Old 07-05-2011, 08:06 PM
put a brand new stainless steel cat on the exhaust system..impossible unless cat already clogged, impossible.
Old 07-05-2011, 08:13 PM
Is the whole exhaust system new, or could there be blockage down stream?
Old 07-05-2011, 08:15 PM
Is the whiole exhaust system new, or could there be blockage down stream?
all new exhaust from the cat back.
Old 07-05-2011, 08:22 PM
It sounds like your doughnut gasket isn't setting right!
Old 07-05-2011, 08:25 PM
OK. is there any proper Procedure for making it set into place? ive spinned it with my fingers all the way around and it doesnt have a setting....
the gasket is the right size, this is a fact. Although the most important piece of information i can give is when the bolts are tightened all the way the gasket can still spin with my fingers...
Old 07-05-2011, 09:06 PM
It shouldn't spin after you tightened it!
Doe's the exhaust flange use bolts, or nuts?
If nuts, or bolts you might need to add some washers, berfor the nuts so you can torque thr exhaust flange down proper.
Old 07-05-2011, 09:09 PM
If nuts, you might need to add some washers, berfor the nuts so you can torque thr exhaust flange down proper.
both nuts and bolts. on one of them the but will thread loose and on the ohter one the nut is seized on....maybe the springs are worn out then?? they look new though..
Old 07-05-2011, 09:14 PM
Can you push the exhaust header into the exhaust manifold?
Old 07-05-2011, 09:23 PM
my car has a manifold. do you mean can i push the flange into the manifold??
Old 07-06-2011, 07:49 PM
ok problem solved. GOD DAMNIT i had the damn gasket in upside down! well first time ive worked on exhaust system pretty much. make sure the doughnut goes on the right way and that it goes in evenly. and all is good now. thanks everyone though for youre inputs.
Greg
The Following User Says Thank You to 1994cavalier For This Useful Post:
danielsatur (07-06-2011)
Old 07-06-2011, 08:18 PM
There's very few DIY exhaust technicans, I usually buy my own mufflers, catalytic converters, and H02 sensors as needed Online & let the muffler shops do the install.
how to fix small leak in gas tank StewartFan20 LeSabre 2 11-18-2007 10:34 PM
1994 Cougar XR7 3.8 V-6 exhaust leaks, easiest way to fix? 460 mustang Cougar 1 01-13-2007 08:34 PM
how do u find an exhaust leak? fdu98 Rodeo | Passport | MU 1 10-17-2006 11:12 PM
exhaust leak fixed. intake manifold leaking! ghostrx7 RX-7 2 04-22-2005 12:10 PM
Any "Easy" Fixes for an exhaust leak? lovemylandrover Discovery | LR3 | LR4 0 07-03-2004 01:46 PM
