Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 07-03-2011, 07:01 PM
Cadillac style Cadillac style is offline
Unhappy 92 Cadillac Seville idle problem
My 92 Seville has140,000 miles on it and when I got it the minimum air (idle speed) screw was missing but the car was running fine then 2 months down the road it started dying at low speeds in traffic or at red lights the idle fluctuated from high to low very quick I stopped driving it for one week and now it has a hard time starting up and idles at 500 Rpm for two seconds then dies out. I changed my spark plugs and wires gonna change the starter after July 4 and gonna change idle motor because has an idle screw I really don't know how to diagnose a vehicle but could use any information or ideas a person has to help cause I love that car
Old 07-04-2011, 07:42 AM
maxwedge maxwedge is offline
A990 racer
Re: 92 Cadillac Seville idle problem
You need to set the minimum base idle using the set screw that you say was missing, then the idle control motor takes over, also the tps may need adjustment, this procedure is tricky I suggest getting a good shop manual.
Old 07-06-2011, 06:25 PM
Talking Re: 92 Cadillac Seville idle problem
Thank you so much
1979 Seville a/c blower works good...sometimes???Anyone? fleetwoodknapp Cadillac Classics 3 06-04-2010 06:13 PM
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
