Old 07-02-2011, 03:47 PM
Markb873 Markb873 is offline
4L60E Surging
Hello,
I have the 4L60E transmission. I am having a surging problem with it. I can control it with a bottle of lucas for a few thousand miles however due to a fairly large leak into the transfer case the lucas dilutes when adding new fluid and by the time the fluid leaves the transfer case it's pretty dirty so it's never added back in.
I will be pulling the transfer case off to replace that seal, and hopefully not the output shaft. and i might as well fix the transmission too while i'm down there.
My questions are: Does this seem characteristic of a worn pump, or torque converter? I feel like I am leaning to the torque converter because the transmission still shifts flawlessly, other than a 1 to 2 hard shift which is eliminated by adding the Lucas. It seems to that the torque converter is trying to stall the engine on ocassion when it is first started too.
fyi - 1993 s10Blazer 149,000 - No Trans DTCs
-Mark
The cars on the lawn:
2000 Kia Sportage
1993 Chevrolet S-10 Blazer
1975 Radio Flyer Wagon
Old 07-03-2011, 03:58 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 4L60E Surging
Originally Posted by Markb873 View Post
Hello,
-Mark
Describe the surging a little more?
Like in what gears/hot or cold/engine surge/or transmission slipping/or just transmission surge.
Make sure engine is runnuing good for transmission to work good.
A transmission capable sanner and a transmission pressure gauge will show transmission problems in data read out and transmission pressure loss.
Watch data for slipping and shift time and pressure lose when surging.
Was it checked for transmission codes with a transmission capable sanner?
If adding lucas helps it sounds like you have internal transmission pressure problems.
Does it act up when transmission is full of fluid?
Is the filter and fluid in good condition?
If you are going to pull transmission out it will be a good time to give it a complete rebuiold or replace it.
MT
Old 07-03-2011, 09:25 AM
Re: 4L60E Surging
The surging generally occurs at a fairly heavy throttle. More noticeable in the lower gears. It's not a lack of fluid slippage. It seems to be a varying load on the engine. Engine runs good. I notice it seems to do it more when hot.
The filter is in good shape, no abnormal metal in the pan. The fluid is constantly leaking into the transfer case so it always looks and is fairly new on the dipstick. I am draining about 5 quarts every 10,000 out of the transfer case. When I top it off I really don't notice a difference. Although adding the Lucas makes a substantial difference.
The codes were checked through grounding A+B.
Sounds like I need to get it pressure checked at the transmission shop.
Thanks again,
Mark
2000 Kia Sportage
Old 07-03-2011, 05:30 PM
MT-2500's Avatar
AF - Advisor
Re: 4L60E Surging
Thanks again,
Mark
You are welcome..
Yes and have them put a transmissin capable scanner on it.
You can not get all transmission info and codes from a A&B JUMP.
Surging is sually engine running problem.
Engine has to run good for transmission to work good.
If a bad flud leak to transfer case it may have been run low on fluid urning clutches.
Let us know how it goes.
MT
4l60e Transmission out again...need help remington8189 Silverado 6 10-08-2014 04:16 PM
97 4L60E Trans problem mavbeacon Silverado 9 10-07-2012 12:28 PM
4l60e shift issues after rebuild onedbdred C/K 3 02-14-2010 01:26 AM
04 3400 GASE Power surges. cboy2us Grand AM 4 08-26-2009 11:57 PM
Silverado Corvette Servo 4L60E Silverado_Dude Silverado 0 08-14-2009 08:50 PM
