Old 06-30-2011, 02:57 PM
someday31 someday31 is offline
Bed tie downs strength
I have a 03 1500 silverado....I am looking to put a chain across the bed at the two tie down posts in the bed. Off that chain I want to put a winch to pull up tractors/mowers up ramps. Is this something my bed can support. Most the mowers would be around 800-1000lbs. I have a Pro Tec Composite Bed if that matters.
Old 06-30-2011, 04:58 PM
j cAT j cAT is offline
Re: Bed tie downs strength
I don't know how strong those points are. I would say that it would not take 1000lbs of force to pull a tractor or other equipment with wheels up into the bed... I would buy a small trailer and use that instead of the truck bed. much easier to load unload..that is if you plan on doing this all that often...
using a 1/4 inch steel plate16 inches square , bolted to the truck bed then mount a 12 volt electric winch on that plate..that should do it safely..
The Following User Says Thank You to j cAT For This Useful Post:
cf1 (06-30-2011)
"pop-up" tie downs Nigel215 Silverado 2 02-23-2005 07:00 AM
Can I switch the battery tie down to the other side? Melt '88 - '91 Civic | CRX | Wagon | Shuttlee 10 11-10-2002 02:28 PM
Battery Tie Down G20Rob3 Cosmetics 1 12-27-2001 04:33 PM
Hi-Lift jack tie-down rrdstarr Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 14 12-07-2001 02:18 PM
