Old 11-08-2002, 07:26 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Can I switch the battery tie down to the other side?
I had to get a new battery, and they only had 92+ batteries which has the terminals on the other side, so is it possible to switch the tie down, cause me and my dad might attempt this tommorow
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 11-08-2002, 08:33 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
It should work, except i think the rods to hold the bottery tight may be to long then...should be easy enough to fix...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 11-08-2002, 09:25 PM
jc836 jc836 is offline
The real simple answer here is that you should not do it. Rather see you swap for the battery with the posts on the opposite side from where you now have them. My Die Hard is a model 30051 and the connections are on the side closer to the fender versus the way yours are. I might add that my AEM short Ram clears perfectly.
Grandpa toys-Modded suspensions and other tweaks
'89 CRX Si PDA/NASA/SCCA/Steel Cities ITA pocket rocket
'99 Prelude Base SS - A Sweet Song in Motion
'03 Dodge Dakota Club Cab-gonna tow the CRX
Old 11-08-2002, 10:27 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Turn the battery around.
Old 11-08-2002, 11:33 PM
Melt's Avatar
if I turned the battery around the connectors wouldnt reach. I had a battery with posts on the other side before this one, and yes, my intake still cleared. Hopefully moving the mount will do it, or else off to return this battery to costco and get one over at pepboys or something.
AF Bay Area Crew
Old 11-09-2002, 12:25 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Well, i got a Optima, and this baby just fits in SNUG and this shit wont move around because when you take out the battery tray, it sits right in there perfect!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 11-09-2002, 02:43 AM
91civicDXdude's Avatar
let me ask you this question...do you have an amplifier hooked up in the hatch of your civic? if yes, then you already have step 1 of BATTERY RELOCATION complete. guys this is an easy mod and it eradicates the problem you're having plus other problems like your battery arcing on the intake pipe. It cleans up the engine bay and makes it more spacious. Its been said that putting your battery in the hatch makes for a better weight ratio but i dunno.
anyways
I could write a how-to on this but i think this link http://www.homemadeturbo.com/battery.html probably does a better job.
[img]http://files.automotiveforums.com/uploads/551246darkslam7.JPG[img]
Old 11-09-2002, 04:35 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
what is O/T wire ? i never heard of that. also how much amp is that circuit breaker ?
Old 11-09-2002, 05:58 AM
My reply above is for the Die Hard with the posts on the other side.
Old 11-10-2002, 12:09 AM
civic killer.. i didnt put a circuit breaker on mine and it works fine. the stock battery location doesn't have a circuit breaker besides for fuses. all i did was use my 4 gauge amp wire already ran to the back, unhooked the battery from the front and mounted it in the battery box in the back. then i took a cheap 4 gauge -> (2)8 gauge splitter and hooked that up under the hood to the battery wire and the 2 power wires originally running from the battery positive terminal. on that homemadeturbo.com link, it says to ground the battery in the spare tire hole but i grounded mine to the top of the strut post. very simple mod and gives you a nice custom look...."HEY MAN, WHERES YOUR BATTERY?????" heheh
Old 11-10-2002, 02:28 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Get some new wire. 0 guage should work more than fine
||JEFF| |
Candy Orange 1990 Honda Civic H/B
