Go Back   Automotive Forums Car Chat > MG > MGB
Old 06-29-2011, 02:14 PM
Reggiemom Reggiemom is offline
1974 MGB engine flooding
Help!
I own a 1974 chrome-bumper MGB. The starter (original) was dragging, so mechanic replaced the starter. Upon starting it after that, gasoline started pouring from the run-on valve. Removed the (original) carbon canister and ordered a new one. After installing the new canister, same thing happened PLUS the plastic connectors at the top of the canister broke off. Ordered another new canister and a run-on valve. Replaced both. When attempted to start the car, again one of the carbon canister connectors broke off. Engine smells flooded, as well. Cleaned the plugs and checked the carburetor "float" (oil is up to the top). Any ideas, please? Could it be the fuel pump / too high fuel pressure? Or perhaps could the (manual) choke be stuck open?
Thanks for any help you can provide.
Old 07-30-2011, 08:03 PM
rocannon rocannon is offline
Re: 1974 MGB engine flooding
1) check that fuel pressure isn't over 3 psi. 2) if pressure is ok, then check the needle valves in the float bowls. the canisters aren't the problem... you're getting gas from the carbs overflowing via the vent lines into the canisters.
1974 mgb flooding problem vjl5184 MGB 0 10-06-2010 06:25 AM
1974 MGB Won't Start again AustinMG MGB 3 01-12-2008 09:19 AM
1974 MGB GT Hood reggo3636 MGB 0 03-14-2007 04:46 PM
1974 MGB Won't Start - Part 2 AustinMG MGB 5 09-05-2006 09:16 AM
1974 MGB with v-6 BOOMERce MGB 1 10-12-2003 04:09 PM
