Old 06-28-2011, 02:44 AM
hotrodsd51 hotrodsd51 is offline
2000 Olds Intrigue Trans Identification
I went to purchase a used transmision for my Intrigue and was told there are a few diff tranny's for this car. Where do I locate the numbers and or letters to identify what tranny I have? 2000 olds intrigue 3.5
Old 06-28-2011, 04:40 AM
procaddytech procaddytech is offline
Re: 2000 Olds Intrigue Trans Identification
The trans shlould be a 4T65-E with 2 different final drive gear ratios. Find your RPO code sticker. (in the trunk on the spare tire cover maybe) Check for RPO M15 which will indicate a 4T65-E. Then FR9 for a 3.29:1 ratio or F83 for a 3.05;1 ratio. You can also write down all the information on the trans id tag which is on the right rear side of the trans between the forward band servo cover and the right axle.
The Following User Says Thank You to procaddytech For This Useful Post:
hotrodsd51 (06-28-2011)
2000 olds intrigue kellyb1 Intrigue 7 10-14-2010 01:35 PM
99 olds intrigue sunroof issue!!! smity9089 Intrigue 1 03-22-2009 09:21 PM
Part number for 2000 Olds Intrigue (TCC PWM solenoid) teddie1960 Intrigue 5 02-28-2007 06:22 AM
AC Compressor for 2000 Olds Intrigue trhodes Intrigue 5 04-12-2006 06:06 AM
2000 Olds Intrigue Alternator Help lumberman907 Intrigue 1 09-08-2005 07:34 AM
