Old 10-11-2010, 01:23 PM
kellyb1 kellyb1 is offline
2000 olds intrigue
Car recently started sputtering, had code pulled and it stated that cylinder 3 was misfiring. Since then I've changed plugs on cylinders 1, 3, and 5 and also did a swap of the coils and still happening. Did not have code pulled again but was wondering if it could be the coil or injector problem. Any thoughts wouldbe appreciated.
Old 10-11-2010, 04:50 PM
dtownfb dtownfb is offline
Re: 2000 olds intrigue
First thing to do is pull the code again to see if it is the same or different code.
Second thing is to try and isolate when the sputtering happens.
Third, post the exact code. There are very few problems that this group has not faced with this vehicle.
Old 10-11-2010, 10:28 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Yes you need to pull the code again, it could be that your code has "moved" to a different cylinder because of the coil swap.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 10-12-2010, 12:21 PM
krivasauto krivasauto is offline
Banned
Loosing any coolant?
Old 10-12-2010, 04:40 PM
tacosoldier tacosoldier is offline
My question is, have you run the car while it was overheating? If so, either the heads or the head gasket is cracked and causing coolant into the combustion chamber.
My mother in law had this similar situation and after the replacing the head gasket the misfire troublecode hasn't reappeared and her engine runs smooth again.
Old 10-13-2010, 03:22 PM
Banned
Well, don't jump to any conclusions. Head gaskets can fail without the vehicle overheating, and you can have an engine run hot without blowing the head gaskets. Block testing is the best way to figure it out, unless, like on mine, you pull the plug and see coolant in the combustion chamber.
Old 10-13-2010, 07:38 PM
LittleHoov's Avatar
If you were burning coolant the plug you pulled out of cylinder #3 should look quite a bit different than the others you changed.
I still maintain you should get the code checked again as you might have a different cylinder thats misfiring now.
If you can confirm youre getting good spark, I think a compression test might be the next easiest thing, though Im sure some sort of adapter or tool might be required due to the long,narrow spark plug channels on the 3.5
The only other thing after that would be to confirm that the injector is working properly, and the only way to really do that is pull the fuel rail out. You can however check to see that the electrical pulse is making it to the fuel injector with a simple test light. You might just have a broken wire somewhere.
I would still think a compression test is easier that pulling the fuel rail, but that sounds like the sort of thing krivasauto could tell you....
Some people put together puzzles or build models for fun....Krivasauto takes apart Intrigues.
Old 10-14-2010, 01:35 PM
Banned
olds intrigue fuel door and trunk release issue smity9089 Intrigue 2 11-02-2009 10:09 PM
99 olds intrigue sunroof issue!!! smity9089 Intrigue 1 03-22-2009 09:21 PM
Part number for 2000 Olds Intrigue (TCC PWM solenoid) teddie1960 Intrigue 5 02-28-2007 06:22 AM
AC Compressor for 2000 Olds Intrigue trhodes Intrigue 5 04-12-2006 06:06 AM
2000 Olds Intrigue Alternator Help lumberman907 Intrigue 1 09-08-2005 07:34 AM
