Go Back   Automotive Forums Car Chat > Honda > CL | Inspire | Saber | TL
Old 06-27-2011, 03:04 PM
Davidcarter922 Davidcarter922 is offline
Question Removing spark plug wires
My 1999 Acura CL2.3's engine light came on. Diagnosed as Code P0303 - misfire in 3rd cylinder. Tried to pull wire for 3rd cylinder from engine and could not. Twisted it, still no. Finally just the wire came out!! It pulled out of the crimp! Carefully pushed it back in. Car runs same as before. Engine light has not come back on yet (I reset it) but the misfire is still happening. How can I check this out and have I done any damage by pulling this wire?
Old 07-02-2011, 11:29 PM
BullShifter's Avatar
Re: Removing spark plug wires
I would suggest replacing the plug wires. If you have a misfire and a bad wire now you have 2 things going on. Since you are doing wires, you might as well do the plugs. If the cap & rotor haven't been replaced in a while you should do those as well. I suggest using all OEM parts. Just by replacing those parts you might fix the miss. If that doesn't fix it there is usually one other culprit - Fuel Injector.
Old 07-03-2011, 12:42 AM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Just do a routine tune up as far as the misfire is concerned...plugs, wires, cap and rotor. If that doesn't cure the misfire problem, you may have actual engine failure. Pull the #3 spark plug and look/smell it...if it has gas on it...that's a good indication that a tune up will fix the problem, However if it has oil on it then that is a VERY bad thing. Oil means (probable) head gasket failure.
How to remove spark plug wires sprocket401 Cavalier Problem Diagnosis 5 04-04-2009 08:16 PM
spark plugs freakyfire05 ZX2 2 02-17-2009 12:03 PM
