Old 03-28-2009, 07:52 PM
sprocket401 sprocket401 is offline
Question How to remove spark plug wires
I need to replace the spark plug wires on my 1997 4 cyclinder Cavalier. Does anyone know how to get to the wires that are on the coil to remove them?
Old 03-28-2009, 08:20 PM
ctwright ctwright is offline
Re: How to remove spark plug wires
There should be a hood latch lever somewhere around your dash I believe.
Old 03-28-2009, 08:41 PM
J-Ri's Avatar
J-Ri J-Ri is offline
The engine size makes adifference here, because the two are entirely different. Lets always try to post all info about a car (everyone, please?).
Either remove the cover or go in from below. If you need more than that, give us the engine size.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-28-2009, 08:46 PM
I was just joking with my post but you replied to mine and talked as you were speaking to the person who started the thread.
Old 03-29-2009, 01:44 PM
J-Ri's Avatar
The "" was my response to you. Everything else was to the OP.
Old 04-04-2009, 08:16 PM
ricebike ricebike is offline
wasn't hard for me
my sis' car had a 2.2L engine
is your's the 2.4L engine? then i don't think you have wires
confirmed:
Coil on plug insulator and terminal
so yea, if you have the 2.2L, the wires are easily visible and routes to the back of the engine
they're hard to reach if its between the firewall and intake manifold, get someone w/ skinny arms and let them change it out, one at a time
