Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-24-2011, 11:26 AM
Ehrmy1 Ehrmy1 is offline
92 Cutlass Supreme Intermittent Starting
I have 92 cutlass supreme Sl 2dr. 3.1 with 180,000K. When I try to start it I can hear the starter solenoid "snap" into place but it may or may not turn over. All interior lights/dash are lit up. I have replaced the battery and a recondioned starter. The wires and grounds all look good. When it does turn over it turns over freely with lots of juice. I have an old auto start in the system but bypassed and I have checked the byass switch and it is ok as it still may happen with the switch bypassed. Is there any other elec. parts that may be the problem(Ignition coil or module). Where are these parts situated on the car?Is the starter a bad replacement from Canadian Tire? Any help would be appreciated.
Old 06-24-2011, 12:38 PM
maxwedge maxwedge is offline
A990 racer
Re: 92 Cutlass Supreme Intermittent Starting
If the starter attempts to crank and fails, it is either the starter, the engine is binding up or a bad ground or battery connection, based on your description.
Old 06-24-2011, 02:30 PM
It was doing the exact same thing before I changed the starter. Is there two seperate current flows to the starter, one to engage bendix and one to give turning current to starter?
Old 06-24-2011, 07:41 PM
A990 racer
The ign switch powers the solenoid egagemment, but the large battery wire powers the starter itself.
Old 06-26-2011, 01:57 AM
aleekat aleekat is offline
"Wires and ground look ok" Don't go by look. Lots of wires get corroded under the sheath. Just because the dash lights light up doesn't mean anything. Very little current to light up the lights.
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 08:15 AM
Possible Exhaust Back pressure on 96 Olds Cutlass Supreme chrisluna Cutlass Series 4 10-16-2009 06:01 PM
96 Cutlass Supreme with Alternator trouble chrisluna Cutlass Series 4 10-05-2009 05:34 PM
96 Cutlass Supreme w/ humming noise coming from under the back of the car chrisluna Cutlass Series 1 09-28-2009 01:11 PM
92 Cutlass Supreme Intermittent Problem Arinath Cutlass Series 1 11-11-2007 10:16 AM
