Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-24-2011, 10:54 AM
tirwin88 tirwin88 is offline
3 Codes...are they all tied together?
My car started sputtering on take off and jerking a little when driving. The engine light came on. I took my code reader and it pulled up 3 codes. PO128 which said it was the Thermostat, PO404 and PO405 (EGR)? Coud these all be tied in together? What part should I replace? The car is a 2003 Chevy Impala.
Thanks!
Old 06-24-2011, 12:29 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 3 Codes...are they all tied together?
Go to http://www.obd-codes.com , a site that lists all the codes . You may get a clarification there . Good luck !
" Sometimes I grow so tired "
Old 06-24-2011, 04:08 PM
j cAT j cAT is offline
Thanks!
your engine requires a 195 deg f thermostat. this code is saying the engine is too cold. could be thermostat or the ECT sensor.
the EGR code may be due to the low temp code..first correct that as the egr only operates when the engine is at the correct temp...
Are They All Made In Japan??? awcforever tC 2 04-30-2007 06:57 PM
91-98 base model muffler, are they all the same? HKmitsubishiman 3000GT/Stealth 1 07-08-2004 02:46 PM
G2 4g63t - are they all the same? psyhofreak Off-Topic 2 12-31-2003 08:25 AM
