Old 06-23-2011, 10:24 PM
sbriar sbriar is offline
Bench Bleeding 96 Lumina sedan
I bought a new Master Cylinder from NAPA and need some help on how I should Bench Bleed this thing.
All I could find on the Youtube videos were how to Bleed 2 line Master Cylinder's, this one has 4 lines.
Do I need to Bleed each port or just the two bottom ports or the two furthest ports away from the push rod or, or, or.
The kit came with 2 plugs and 2 hose fittings and 2 hoses.
This is a non ABS system
Thanks
Steve
Old 06-24-2011, 03:12 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Bench Bleeding 96 Lumina sedan
I've only ever done 4 line master cylinders one way.
Install it on the car, fill it, put the bench bleed hardware on the front two ports, leave plugs in the rear. Press the brake pedal slowly 3/4 stroke careful not to bottom out hard, repeat until you feel the pedal firm up as good as it can get. Take the bleed hardware off, install the front 2 brake lines, pull the plugs from the rear ports, install bleeder hardware and repeat above until the pedal feels good. Install your rear lines and you're done.
The Lumina has a split diagonal system, meaning each of the two pistons works one front and one rear wheel. The proportioning valves are built into the master cyl, that's why it has four lines instead of two.
Have plenty of water near you and douse any leakage with it once you're done, so the brake fluid doesn't eat anything it falls on.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Do I really need to bench bleed new master cylinder before installation? deesandvees Caprice 3 11-20-2009 12:03 PM
Bench bleeding new master cylinder pharm_rodeo Integra 0 02-13-2007 10:08 PM
How to bench bleed brake master cylinder? tfoti Eclipse Problem Diagnosis 4 02-10-2007 10:44 AM
bench bleeding Coolguy1181 General Discussion 0 10-20-2003 12:44 PM
Bench Bleeding Coolguy1181 Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 10-20-2003 12:34 PM
Tags
bench , bleeding , cylinder , master
