Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-19-2009, 07:18 PM
deesandvees's Avatar
deesandvees deesandvees is offline
Do I really need to bench bleed new master cylinder before installation?
Says to in the instructions...seems like one of those things I've never seen done and has never caused a problem.
'87 Landau
Old 11-19-2009, 09:45 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Do I really need to bench bleed new master cylinder before installation?
Well, if you don't want to lose brakes and crash your car the first time you take it out with the new cylinder, it might be a good idea to...
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-20-2009, 04:59 AM
Yah I guess that's a good enough reason I guess I need some bleeder plugs then (as per instructions).
'87 Landau
Old 11-20-2009, 12:03 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Master cylinders sometimes come with the plugs and some tubing to bench bleed. It really makes the bleeding process easier to do it on the bench, that way you are not pushing all that air thru the system.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
