Old 06-22-2011, 08:56 AM
chubcobear's Avatar
chubcobear chubcobear is offline
Possible to bypass A/C compressor?
Thanks for all the help. White Buffalo, Dorman bypass pulley will be a good solution. Do you have a tip on who sells it? Thanks. '95 Lesabre limited.
Old 06-22-2011, 09:27 AM
maxwedge maxwedge is offline
A990 racer
Re: Possible to bypass A/C compressor?
Napa, Carquest, for sure.
Old 06-22-2011, 10:08 AM
chubcobear's Avatar
Thanks Max, I found it. It is Dorman Item #34202 a/c bypass pulley. Couple of local O'Reilly & Autozones have it around here.
Old 06-30-2011, 07:00 PM
chubcobear's Avatar
Further to this discussion, I was able to make the switch from a/c compressor (dead) to Dorman idler puller part. I had to go to a local mechanic and have the freon legally removed and then I removed compressor, plugged hi/low lines, and reinstalled the serpentine belt. When/if the compressor is replaced, we will have to install new accumulator, filter and expansion tube. Maybe more stuff. Thanks to all.
EVAP Canister Issues/Possible bypass? sk8injon Engine and Transmission 1 07-25-2009 08:39 AM
bypass a/c compressor 97 caravan chjohnson Caravan | Voyager 1 08-21-2005 09:09 PM
bypass A/C compressor bouliancube Beretta 2 03-29-2005 05:24 PM
90 GrandCaravan - bypass a/c compressor? austin.andy Caravan | Voyager 2 03-02-2005 07:54 AM
can i bypass the ac compressor? bpvs Cherokee 3 05-03-2004 10:01 AM
