Go Back   Automotive Forums Car Chat > Cars in General
Old 06-22-2011, 09:47 AM
danielsatur danielsatur is offline
Broken drivers door mirror
Liquid nails works better instead of duct tape!
If the mirror glass is broken, a replacement can be found at the local Auto parts store.
Old 06-24-2011, 10:20 PM
porcupine73 porcupine73 is offline
Re: Broken drivers door mirror
The heavy duty construction adhesive at Home Depot works pretty good, just do not get it on your hands, because it will not come off. It has to wear off and that takes about a week. That stuff hardens up almost like steel, but it does take like 24 hrs to harden, so maybe adhesive, then duct tape for 24 hours or more so it can harden up nice. Then you're sporting!
Old 07-02-2011, 07:35 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Is this the ghetto wallmart fix?
Old 07-02-2011, 08:36 PM
LOL- It all depends were you buy your glue!
It also works good on inner door panels with bad plastic clips.
Old 07-02-2011, 08:43 PM
Moppie's Avatar
Master Connector
Just as long as you don't want to get the panel off again in the future.....
The new plastic clips cost less than liquid nails anyway
Old 07-03-2011, 09:23 PM
It also works great for other exterior parts that are made of plastic.
Old 07-04-2011, 03:48 AM
Moppie's Avatar
Master Connector
Cheap 2 part epoxy works as well.
I've used it in the past to fix up a broken air take and even a radiator header tank.
Old 07-06-2011, 04:36 PM
It seems like differnet types of plastics require different types of glues, and I noticed that liquid nails doen't care.
Old 07-07-2011, 02:56 AM
Moppie's Avatar
Master Connector
True, but Epoxy will stick to anything as well.
At least liquid nails will work better than metal nails.......
Old 07-07-2011, 09:08 AM
It doesn't rust!
automatic locks and driver side window not working rmwilson Problem Diagnosis 5 06-23-2010 09:04 AM
04 yukon xl driver door instrument panel problems kminton85 Yukon 0 01-09-2010 11:57 PM
2001 Auto Dimming driver door mirror Beachbums LeSabre 6 09-29-2005 08:09 AM
Drivers door/ lock, elec. mirrors, int. lights, door ajar light JamesD Explorer | Explorer Sport Trac 5 04-08-2005 10:42 AM
72 Javelin sst driver door mirror Javelin712 Engineering/ Technical 0 08-30-2004 12:16 AM
