Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-21-2011, 03:28 AM
dreak911 dreak911 is offline
Unhappy 99 Exploer AWD 5.0 Wont turn Over
i have a 99 ford explorer 5.0awd ive replaced the starter aswell as the ignition, ive changed out relays, and fuses... i came home one night parked and it dinged even after i took the keys out, i dont know what else to do at this point... Any Ideas!?
Old 06-21-2011, 06:43 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 99 Exploer AWD 5.0 Wont turn Over
Welcome to the forum!
In the past I've seen several different meanings behind "won't turn over" so I'm going to ask for some clarification. When you turn the key to the "Start" position does the starter motor engage but the engine fails to start, or do you just get a click or series of clicks? When you say you've replaced the "ignition" what does that include? The "ignition system" typically is considered the coils, spark plugs, spark plug wires, crankshaft position (CKP) sensor, and camshaft position (CMP) sensor.
-Rod
Where is oil sending unit 98 Explorer 5.0 Hedhunter Explorer | Explorer Sport Trac 2 02-13-2010 01:19 PM
WTS: 1979, Ford Mustang 5.0 Auto, Coupe, 105,000 orig. miles kevin2e Classifieds 3 12-02-2009 10:49 PM
1986 5.0 turns over but won't start 86_5.0 Mustang Problem Diagnosis 2 06-24-2009 05:50 PM
1989 chysler Lebaron 2.5 turbo convert. wont turn over stover555 Lebaron 3 05-25-2006 10:52 AM
2000 1.0 wont turn over at all.. IAN442 Metro 7 07-26-2005 04:32 PM
Tags
1999 , 5.0 , awd , explorer
