Old 07-24-2005, 02:49 AM
IAN442 IAN442 is offline
2000 1.0 wont turn over at all..
hell it wont even pop start...
ran fine to work,,,went to move the car and nothin. I ran a bypass wire to the solenoid...nothin.
also did never hear the fuel pump engage either, and the radiator fan or a/c fan just runs nonstop...
i pulled the starter for getting it tested just now...and the car is still stuck at work.
i checked the neutral switch and it seemed fine but i could not still get anything out of the starter - soloenoid.
Any Suggestions ? - thank you in advance.
Old 07-24-2005, 08:22 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 2000 1.0 wont turn over at all..
sounds like dead battery, blown main fuse or bad starter
Old 07-24-2005, 10:49 AM
main fuse is the one under the hood one of the large 12 amp ones right ?
Battery is good, I got a separate Battery and voltage tested both...
I took out the starter and had it tested and its good...
Old 07-24-2005, 08:14 PM
geozukigti geozukigti is offline
Is the ground wire that goes from the firewall to the distributor any good? That ground is required for the starter.
Old 07-25-2005, 02:10 PM
Crvett69's Avatar
main fuse is a 40 or 50 amp, will be several under hood with different colors, about 1/2"x3/4"
Old 07-25-2005, 04:45 PM
Broken ground wire from negative post to transmission housing did not see it before because of the way it was connected and terminal connection hidden, took me bumping the wire to get it show a plain cut, so off to get a new negative cable for the battery...
Old 07-25-2005, 06:09 PM
I was close good find.
Old 07-26-2005, 04:32 PM
In the end total cost to replace cable and new battery connector $9.00
Experience gained by checking all the systems out...priceless.
