Old 06-17-2011, 05:30 PM
cruiser69 cruiser69 is offline
Starting Issue
I have a 2002 GT 3.8L with 90k on it. About twice a week lately it will not want to start. It cranks fine and then dies. If I keep my foot on the gas for a few minutes it all of a sudden idle fine and runs fine. Could my fuel pump being going out? Let me know if anybody has any ideas. Thanks.
Old 06-17-2011, 09:18 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Starting Issue
Try cleaning the IAC valve first with throttle body cleaner, carbon builds up on the plunger and causes a hard time starting the engine.
Holding your foot on the pedal does not helps anything with the fuel system, AFAIK when you do that the PCM detects it and causes the system to stop spraying fuel to avoid a rich fuel mixture in the cylinders.
A bad fuel pump problem could be possible if you have to prime the system (turn the key on and off) several times before cranking the engine in order to build enough fuel pressure on the lines. This could also indicate a bad Fuel Pressure Regulator, remove the vacuum hose running to the top of it and inspect for any fuel dripping from it.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 06-19-2011, 09:37 AM
Re: Starting Issue
I just replaced the IAC and fuel pressure regulator in February. I will check them, but I would hope they are not bad yet.
Old 06-20-2011, 12:03 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Starting Issue
With the car off, try disconnecting the MAF (Mass Air Flow) sensor and then start the car with it disconnected to see if it stops. Your symptoms are one of the first indications a MAF is failing, and when they do this, they don't neccessarily trip a CEL or code. If it runs better this way, the MAF is the issue. If nothing changes, it's time to get a fuel pressure gauge and see if you fuel pressure is within spec.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-20-2011, 12:20 PM
Scrapper Scrapper is offline
AF Premium User
Re: Starting Issue
i would put a can of seafom in gas to clean your injectors it's a cheap way to see whats taking place on your car idling you can get it at autozone,advanced about any parts place even rual king. you can try to clean maf sensor it may be what he said also iac need cleaning? one more thing the cat might be plugging up?
Old 06-24-2011, 06:39 AM
Re: Starting Issue
I unplugged MAF and no change. What should the fuel pressure read when I test it?
Old 06-24-2011, 01:19 PM
richtazz's Avatar
Re: Starting Issue
Book specs are 48-55 psi key on/engine off, with a 3-7 psi drop with the car running and the fuel pressure regulator vacuum line attached. In the real world, we've had members with pressure as low as 40psi and having no issues.
96 S10 Ignition/Starting Issue fmhsgrad96 Problem Diagnosis 5 05-25-2012 08:19 PM
99 Denali No Start Issue Denali4485 Yukon 3 10-18-2010 07:48 AM
Grand AM 96 3100 V6 Starting Issues Alfredogalvan Grand AM 6 11-13-2009 09:40 PM
Rx7 turbo issue/starting issue/all kinds of stuff...any advice is appreciated neffsrx7 RX-7 2 09-03-2009 02:25 PM
Help! Starting issue sunfire96 Problem Diagnosis 5 04-12-2009 11:57 AM
